Silver_05_GTX Posted December 17, 2009 Share Posted December 17, 2009 I just replaced the stock battery in my LGT with a Gold from Autozone. I noticed that the posts are smaller diameter than the stock posts, so the installer put some kind of sheathing over the post before connecting the terminals. I also noticed that there is a black plastic ring on the underside of the negative terminal which made it extremely difficult to get the terminal over the post with the sheath on it. I have seen some discussion re Autozone Gold batteries on this forum, but haven't seen anything about a similar experience. Anyone have the same issues? Link to comment Share on other sites More sharing options...
Rick Posted December 17, 2009 Share Posted December 17, 2009 I just purchased the Duralast gold from autozone this week. Is that the Battery your referring to? If it is then no, I didn't experience the same problem. Link to comment Share on other sites More sharing options...
Silver_05_GTX Posted December 17, 2009 Author Share Posted December 17, 2009 I just purchased the Duralast gold from autozone this week. Is that the Battery your referring to? If it is then no, I didn't experience the same problem. Yes It's the duralast gold. So your terminals were able to be tightened against the post iteslf? Any pics of your terminals/post? Link to comment Share on other sites More sharing options...
Rick Posted December 18, 2009 Share Posted December 18, 2009 You'll have to excuse the poor lighting my iphone doesn't have a flash. Link to comment Share on other sites More sharing options...
Silver_05_GTX Posted December 18, 2009 Author Share Posted December 18, 2009 You'll have to excuse the poor lighting my iphone doesn't have a flash. [ATTACH]77886[/ATTACH] [ATTACH]77887[/ATTACH] [ATTACH]77888[/ATTACH] Thanks very much...This is very interesting...your terminals appear the same as mine... I wonder if the issue is because of the felt rings that they put on the bottom of the posts not letting the terminals seat correctly on mine... Link to comment Share on other sites More sharing options...
Rick Posted December 18, 2009 Share Posted December 18, 2009 Thanks very much...This is very interesting...your terminals appear the same as mine... I wonder if the issue is because of the felt rings that they put on the bottom of the posts not letting the terminals seat correctly on mine... Is there any chance they sold you the wrong battery. I've never heard of different size terminals, but you never know. Is it the same dimension as your old battery? Link to comment Share on other sites More sharing options...
Silver_05_GTX Posted December 18, 2009 Author Share Posted December 18, 2009 Is there any chance they sold you the wrong battery. I've never heard of different size terminals, but you never know. Is it the same dimension as your old battery? The part number is 35-DLG. Link to comment Share on other sites More sharing options...
Kaptan Posted December 18, 2009 Share Posted December 18, 2009 It's the felt rings most likely. I had the same problem using the felt rings they suggest. You just have to push down a little harder and then tighten. Link to comment Share on other sites More sharing options...
Silver_05_GTX Posted December 18, 2009 Author Share Posted December 18, 2009 So I took off the terminal, cap and the felt ring. There is at least 1 mm gap between the terminal and post when the nut is fully tightened. Could the terminals have stretched? Before I replaced the stock battery yesterday the terminal was only disconnected once in 4.5 years. I'm about to go spend another $100 to buy a Subaru battery but don't want to have the same issue if the terminals have stretched. Link to comment Share on other sites More sharing options...
Rick Posted December 18, 2009 Share Posted December 18, 2009 Why don't you just replace the terminals instead? It would be a lot cheaper. Link to comment Share on other sites More sharing options...
Silver_05_GTX Posted December 18, 2009 Author Share Posted December 18, 2009 Why don't you just replace the terminals instead? It would be a lot cheaper. How involved is this? The positive terminal have a number of other cables connected to it and I'm concerned about the compatibility of an aftermarket terminal. Link to comment Share on other sites More sharing options...
Rick Posted December 18, 2009 Share Posted December 18, 2009 This is what I would do. Compare the posts of the Duralast battery to another battery, if the posts are too small or defective take the duralast battery back to autozone and exchange it. If the problem is not the posts on the new battery and your terminals need replaced take the car to Subaru and replace them under warranty. If you out of your warranty, buy the oem terminals and replace them yourself. If your not comfortable with this then have Subaru do the work. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted December 19, 2009 Share Posted December 19, 2009 Am I missing something? Um, lol... I buy my batteries at COSTCO! Link to comment Share on other sites More sharing options...
Silver_05_GTX Posted December 20, 2009 Author Share Posted December 20, 2009 Well I got Autozone to take the battery back, and I went ahead and bought a replacement from Subaru. Oddly enough, I think it's actually the same battery. (and is different from the OE.) Still have the terminal fitment issue...Bringing it to the dealer for new battery cables this week... Link to comment Share on other sites More sharing options...
