jcraw84 Posted September 20, 2010 Share Posted September 20, 2010 So i decided to go with a FMIC. This maybe a stupid question but i searched and cant find anything. When I install my FMIC is there something i need to do to the hood scoop? (would water in the engine bay cause problems?) If there is something I need to buy or something i need to do from preventing a problem please let me know asap (possibly links where i can find the fix). Thanks for the help and once again sorry if this is a dumb question. Link to comment Share on other sites More sharing options...
BradyCat Posted September 20, 2010 Share Posted September 20, 2010 oh boy, dangerous question on the forum.... No you don't need to do anything if you don't want to. 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
jcraw84 Posted September 20, 2010 Author Share Posted September 20, 2010 thanks for the fast help. I was worried about it being a dangerous question and it possibly setting me up to be bashed but i was worried about rain and things like that. Link to comment Share on other sites More sharing options...
DrSpeed Posted September 20, 2010 Share Posted September 20, 2010 Go stealth and do a hood swap with a 2.5i. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
Chameleon Posted September 20, 2010 Share Posted September 20, 2010 Sneaky Dr. Speed ... not a bad idea LOL Link to comment Share on other sites More sharing options...
gotsflat4love Posted September 20, 2010 Share Posted September 20, 2010 Don't worry jcraw84. You didn't ask about soap getting in Link to comment Share on other sites More sharing options...
Strizzy Posted September 20, 2010 Share Posted September 20, 2010 Better yet, look for a 3.0 hood. They aren't as plain as the 2.5i's hood. My bad luck build Link to comment Share on other sites More sharing options...
-TT- Posted September 20, 2010 Share Posted September 20, 2010 don't worry about the hood scoop, but you better make sure to cover the lower part of your grille when you wash your car because you never want to get soap on any kind of intercooler. it could cause really bad things to happen. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 20, 2010 Share Posted September 20, 2010 you have to plug the scoop with bondo after you go with a front mount Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 20, 2010 Share Posted September 20, 2010 don't worry about the hood scoop, but you better make sure to cover the lower part of your grille when you wash your car because you never want to get soap on any kind of intercooler. it could cause really bad things to happen. yes and soap on a FMIC is way worse than a TMIC since the FMIC has a much greater surface area Link to comment Share on other sites More sharing options...
jcraw84 Posted September 20, 2010 Author Share Posted September 20, 2010 here we go again with the soap and intercooler joke. i knew when i asked this that i might start something like the bondo or soap thing. i was just concerned with the water from rain in the engine bay cause i have destroyed electrical parts (sensors and harness shorted) on other cars cause of excess water. Link to comment Share on other sites More sharing options...
cseagle08 Posted September 21, 2010 Share Posted September 21, 2010 If you were closer to Baltimore I would totally swap with you. I want a GT hood at some point. Link to comment Share on other sites More sharing options...
mustangendsley Posted September 21, 2010 Share Posted September 21, 2010 i would think to keep the hood scoop so the engine bay will stay cooler in temps. Link to comment Share on other sites More sharing options...
vr4Legacy Posted September 21, 2010 Share Posted September 21, 2010 I say you create some ducting that will force air down to the FMIC, or vent over to the front brakes.... As for the water issue, I understand your concern, but I don't think enough water is going to get into the scoop, I'm guessing your shorts occured when driving through heavy water and large amounts came from underneath.... Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted September 21, 2010 Share Posted September 21, 2010 Water was getting in there even when you had your TMIC, and any that didnt get evaporated was still in the engine bay, So i would assume yuo would be ok. Id try and get it ducted to either the brakes or the turbo/DP area. Could not hurt to cool the hot parts. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 21, 2010 Share Posted September 21, 2010 I say you create some ducting that will force air down to the FMIC, or vent over to the front brakes.... As for the water issue, I understand your concern, but I don't think enough water is going to get into the scoop, I'm guessing your shorts occured when driving through heavy water and large amounts came from underneath.... due to the second part of your post being serious, I can't tell if the first part of your post is serious or not Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted September 21, 2010 Share Posted September 21, 2010 I try to make sure my hood scoop is full of leaves and twigs and they seem to keep the water out. Link to comment Share on other sites More sharing options...
vr4Legacy Posted September 21, 2010 Share Posted September 21, 2010 due to the second part of your post being serious, I can't tell if the first part of your post is serious or not Honestly I don't think it would help, as the airflow would be minimal to either the brakes of FMIC (and there isn't much room to run ducting) not to mention the fact that the air would be heated by the engine by the time it got to the destination........ so I guess it wasn't all too serious, but what the hell, it may be worth the effort Link to comment Share on other sites More sharing options...
JesseH Posted September 21, 2010 Share Posted September 21, 2010 Haven't some people put a transmission cooler or oil cooler in place of the TMIC? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2010 Share Posted September 21, 2010 They make duct tape in different colors.... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted September 21, 2010 Share Posted September 21, 2010 Haven't some people put a transmission cooler or oil cooler in place of the TMIC? Ive seen a few Auto guys put a tranny cooler up there. Mr_Luv did on his LGT. Looked good and seemed functional! Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 21, 2010 Share Posted September 21, 2010 Honestly I don't think it would help, as the airflow would be minimal to either the brakes of FMIC (and there isn't much room to run ducting) not to mention the fact that the air would be heated by the engine by the time it got to the destination........ so I guess it wasn't all too serious, but what the hell, it may be worth the effort go with your gut instinct Link to comment Share on other sites More sharing options...
DrSpeed Posted September 21, 2010 Share Posted September 21, 2010 Better yet, look for a 3.0 hood. They aren't as plain as the 2.5i's hood. How are they different? BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
LegGTLT Posted September 21, 2010 Share Posted September 21, 2010 Please PM joeleodee For All Site Questions. He is the acting Admin and can resolve anything related to LegacyGT.com Link to comment Share on other sites More sharing options...
Legend Posted September 21, 2010 Share Posted September 21, 2010 I'm guessing your shorts occured when driving through heavy water and large amounts came from underneath.... Personally I like to wear a swimsuit as opposed to shorts, but if the water is coming from underneath perhaps depends are the way to go. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
