Legacytruth Posted June 15, 2011 Share Posted June 15, 2011 Sorry if this has been posted before. Tapatalk search feature BLOWS & I'm not able to log in @ work. I just want to know if the 6 speed in the spec-b series is basically the same strength as an STi trans?I know they came without the LSD & DCCD. I have the opportunity to snag one for a decent price & might swap it in to replace my PPGd 5 speed for better drivability. Thanks spec-b guys ! Link to comment Share on other sites More sharing options...
Legacytruth Posted June 15, 2011 Author Share Posted June 15, 2011 More info. This is for my 06 Baja Turbo. 340/365 to the wheels. I think the 3.90 final drive will be better than the 4.44 I'm stuck with now. (I know I'll need to swap rearends too:)) Link to comment Share on other sites More sharing options...
Drift Motion Posted June 15, 2011 Share Posted June 15, 2011 SI drive does nothing with the tranny, AFAIK it changes boost/timing/etc. The tranny is the same minus DCCD, this is why they are a bit cheaper than the STi 6mt. They can be swapped into the WRX, however I am not sure if any changes need to be made for the axles. I seen a thread on this a couple years ago when a few people here were using them as they were much cheaper at that time. http://forums.nasioc.com/forums/showpost.php?p=24676017&postcount=2 http://forums.nasioc.com/forums/showthread.php?t=1650581 Link to comment Share on other sites More sharing options...
Legacytruth Posted June 15, 2011 Author Share Posted June 15, 2011 http://forums.nasioc.com/forums/showpost.php?p=24676017&postcount=2 http://forums.nasioc.com/forums/showthread.php?t=1650581 Thanks! That's EXACTLY what I was looking for. Link to comment Share on other sites More sharing options...
RJS5689 Posted June 16, 2011 Share Posted June 16, 2011 The SpecB transmission also has a larger, heavier flywheel than the STI's (which also means a different pressure plate as well). When my clutch went in the SpecB, I used all STI specific parts as replacements. You just need to make sure you've got the right size pressure plate and flywheel as they are different between STI and SpecB. Link to comment Share on other sites More sharing options...
