mk6933 Posted October 18, 2011 Share Posted October 18, 2011 So this is what happened. I parked my car at a parking lot. When I was trying to start my car, it went through all the normal gauge sweep, then my whole car just died. Nothing worked, power locks, keys, etc. I had someone trying to jump start for me, but there was sparks coming from the positive terminal then it starts. I drove back home, turn my car off, then turn it back on. Nothing works! My whole car just died. What should I do? My car is still under warranty. Should I tow it to a nearest dealership? I appreciate any help. Thanks! Link to comment Share on other sites More sharing options...
alexxdj1 Posted October 18, 2011 Share Posted October 18, 2011 Call the dealer for sure. Personally I have a Platinum level Die Hard from Sears that has a 3 year warranty on it. Are you running a system in your car like I am? Link to comment Share on other sites More sharing options...
mk6933 Posted October 18, 2011 Author Share Posted October 18, 2011 I only have Hella Horns connected. I'm in the process of removing all wires. Link to comment Share on other sites More sharing options...
alexxdj1 Posted October 18, 2011 Share Posted October 18, 2011 Interesting, well you know that dealer parts are always subpar. Link to comment Share on other sites More sharing options...
mk6933 Posted October 18, 2011 Author Share Posted October 18, 2011 I'm just going to have my car towed to the nearest dealership in the morning. Link to comment Share on other sites More sharing options...
alexxdj1 Posted October 18, 2011 Share Posted October 18, 2011 Good deal, that is always the best cure under warranty. HOpe all is well. Link to comment Share on other sites More sharing options...
ehsnils Posted October 18, 2011 Share Posted October 18, 2011 If it's still under warranty - let the dealer chew on it. It may be something simple like a burnt fusible link. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 18, 2011 Share Posted October 18, 2011 I hope you made sure the battery terminals were clean. Good Luck. Hey if it was a early 09 the battery could be almost 4 y/o so it may be bad. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mk6933 Posted October 18, 2011 Author Share Posted October 18, 2011 Thanks all. I just clean my battery terminals last week. You can still see all the baking soda and acids all over the place. Kinda messy Link to comment Share on other sites More sharing options...
