mattg Posted July 29, 2011 Share Posted July 29, 2011 I'm pretty sure this is coolant/HVAC related. Just noticing it becoming more prevalent in the last couple months. My coolant overflow was empty when I checked a couple weeks ago and I filled it up. Didn't make the sounds go away though. You can hear it even after I shut the car off. Anybody know what the cause/solution is? thx Link to comment Share on other sites More sharing options...
Max Capacity Posted July 29, 2011 Share Posted July 29, 2011 Jack up the right fornt corner of the car as high as you can. Run the engine until the thermostat opens with the cap off the small bottle by the turbo. You can squeeze the top radiator hose too. You have air in the system. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
speertp Posted August 8, 2011 Share Posted August 8, 2011 It's not what you think. It's some kind of a control motor for the heat and A/C system. I think it's the motor that controls where the air goes (defrost, feet, front vents, etc.). My mechanics looked at it and said it would be around $400 IIRC. I guess they have to pull a pretty large chunk of the dash out. I don't remember for sure though. I'm just going to wait until it dies completely to do anything about it. Mine's been doing it for at least 2 years. See if your car is sluggish / incorrectly responding to your commands to switch the air output. Mine will take a second or sometimes I have to push the button a few times and cycle through to get it set right. Link to comment Share on other sites More sharing options...
Lucid Posted September 10, 2011 Share Posted September 10, 2011 Bumping an old thread. OP, did you try this? Did it work? Jack up the right fornt corner of the car as high as you can. Run the engine until the thermostat opens with the cap off the small bottle by the turbo. You can squeeze the top radiator hose too. You have air in the system. Link to comment Share on other sites More sharing options...
Wagonation Posted September 14, 2011 Share Posted September 14, 2011 It's not what you think. It's some kind of a control motor for the heat and A/C system. I think it's the motor that controls where the air goes (defrost, feet, front vents, etc.). My mechanics looked at it and said it would be around $400 IIRC. I guess they have to pull a pretty large chunk of the dash out. I don't remember for sure though. I'm just going to wait until it dies completely to do anything about it. Mine's been doing it for at least 2 years. See if your car is sluggish / incorrectly responding to your commands to switch the air output. Mine will take a second or sometimes I have to push the button a few times and cycle through to get it set right. Mode control actuator I think it is called - mine has the same problem and noise. Wait for it to fail completely is all you can do. I had a tech listen to it with a stethoscope to diagnose what it was. Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 14, 2011 Share Posted September 14, 2011 I had gurgling. It was the cooling system. Fortunately, unless you have a LOT of air, the system pretty much self-bleeds. With the car stone cold, just make sure coolant is above the pickup in the overflow tank. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
davenz Posted September 21, 2011 Share Posted September 21, 2011 mine does it as well sounds like water lol Link to comment Share on other sites More sharing options...
lilziggy1320 Posted September 21, 2011 Share Posted September 21, 2011 mine does it as well sounds like water lol +1 Link to comment Share on other sites More sharing options...
davenz Posted September 22, 2011 Share Posted September 22, 2011 nice car lilziggy. Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 22, 2011 Share Posted September 22, 2011 mine does it as well sounds like water lol Check the coolant overflow bottle when cold. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
mattg Posted September 22, 2011 Author Share Posted September 22, 2011 After further research it seems like my sound is the HVAC flapper controls behind the dash. The clicking sounds I hear change when I change the vent settings. The diagnosis is to leave it alone until it stops working. Link to comment Share on other sites More sharing options...
Lucid Posted September 22, 2011 Share Posted September 22, 2011 After further research it seems like my sound is the HVAC flapper controls behind the dash. The clicking sounds I hear change when I change the vent settings. The diagnosis is to leave it alone until it stops working. Thanks for the update. I was curious about the jacking-up the right side approach to the "Subaru gurgle and pop". Every subie I've had starts doing it eventually. As long as everything still works correctly, and fluid levels and running temp are good, I'll continue to ignore. Link to comment Share on other sites More sharing options...
Arbitris Posted September 22, 2011 Share Posted September 22, 2011 Shortly after I got my current Subaru I started hearing the gurgling sound from the dash. I checked the coolant overflow bottle and it was dry. I refilled it and, the next day or so the gurgling went away. Link to comment Share on other sites More sharing options...
05LacyGT Posted September 23, 2011 Share Posted September 23, 2011 just noticed mine doing it, sounds like a very quiet dishawsher to me lol. gonna check it out this weekend. Link to comment Share on other sites More sharing options...
ruggerheist Posted September 24, 2011 Share Posted September 24, 2011 ^ thats what mine sounds like but only when the compressor (i think) kicks on. but soon after noticing that sound, a new one popped up. sounds sort of similar but only get it under boost and its extremely faint Link to comment Share on other sites More sharing options...
Tronic Posted March 24, 2017 Share Posted March 24, 2017 Same symptoms and the problem is coolant related and air in the system. The cause is the radiator cap has failed. Looks like it just fell to bits, took off the cap and the spring and rubber was sitting down inside. Its not all metal and the plastic has sheared from age and the constant force of the spring. The 2000 Lancaster 6 appears to be fitted with a 1.1 Bar radiator cap, just fitted a Toyota 0.9 Bar cap as a temporary measure. Link to comment Share on other sites More sharing options...
Dishwasher Posted March 24, 2017 Share Posted March 24, 2017 I had that issue, resolved it by bleeding the coolant using max capacity's method. I was lazy and have a steep driveway though which worked about as well as jacking up the front of the car. I checked the overflow which was empty, and filled it to the "min" line. The issue has not returned. Brought to you by Pfizer Link to comment Share on other sites More sharing options...
