ugotnerice Posted August 8, 2013 Share Posted August 8, 2013 I have a 1997 legacy with a ej22 5 speed. The check engine light is on for the knock sensor but my problem is that when im driving my rpm gauge will go crazy, up and down, sometimes at 0 but the car is still running and accelerating so the rpms should be climbing steady, I also notice that the CEL light gets brighter and dimmer as this happens and sometimes i hear a click from a relay or something? anyone have any idea what would cause this? Link to comment Share on other sites More sharing options...
Tr00b Posted August 9, 2013 Share Posted August 9, 2013 Could be alternator and or voltage issues or loose wires in the cluster. There are multiple clicks that can come but turn your HVAC and cruise off and try again Link to comment Share on other sites More sharing options...
ugotnerice Posted August 9, 2013 Author Share Posted August 9, 2013 thank you, turns out my alternator was bad but after install and driving for 5 minutes the problem came back. it has to be something electrical as when it cuts out then the temp gauge spikes and then when the CEL light comes bright again then the temp goes back down to normal and runs normal as well. Link to comment Share on other sites More sharing options...
Spiral_out Posted February 19, 2015 Share Posted February 19, 2015 Hi, i have the same problem on my 93 legacy, rmp gauge going crazy and temp gauge spikes too, relays clicking, everething... just replaced the alternator and problems continue....did you solve this?? Thanks Link to comment Share on other sites More sharing options...
93ej22 Posted February 19, 2015 Share Posted February 19, 2015 loose or dirty ground wire would be my guess Link to comment Share on other sites More sharing options...
Osei Posted February 19, 2015 Share Posted February 19, 2015 The most common is the ground has broken on the back of the tach on the circuit board. A search for post by JohnEgg will show pics and a fix, If it continues you will get a CEL for torque converter lockup as the engine revs go through the TCU to tell it what speed the engine is at. This will come and go depending on how long the revs are not registering . Just have to remove the tach and resolder. O. Link to comment Share on other sites More sharing options...
johnegg Posted February 20, 2015 Share Posted February 20, 2015 relays clicking, unplug the green test connectors under the dash. they are plugged in for testing only. Link to comment Share on other sites More sharing options...
