BoostOrDie Posted January 14, 2013 Share Posted January 14, 2013 If you have an auto lgt and have bought or have considered buying a lightweight crank pulley you have no doubt spent some time lost in the tangled streams of info on the topic in this forum. And you are also sick of reading "put it in 5th and set the handbrake". I found tips about using over tightened belts and some magical hole under the TMIC. I actually own an auto lgt and have an installed Perrin lightweight crank pulley on it. So let me give you some tips: You may recognize this first picture as the access hole to the bell housing from another post on this topic, occasionally referred to as the magic hole. The hole does exist but if you own an auto finding it wont do you any good. The problem is that on an auto there are no teeth visible, they guy who first suggested using this as a way to tighten the crank pulley has a 5spd. On an auto you just get a nice view of an aluminum shield. http://img.tapatalk.com/d/13/01/14/8e9e5ama.jpg http://img.tapatalk.com/d/13/01/14/davy5y3y.jpg But don't worry! There is an even easier way to gain access to the flywheel (is it called that on an auto?) just put the car up on ramps or jack it up and slide underneath. Find your front diff drain plug, it looks like this: http://img.tapatalk.com/d/13/01/14/ujyhy6u3.jpg Then look a little closer between the diff and the subframe: http://img.tapatalk.com/d/13/01/14/eru2upym.jpg A little closer still: http://img.tapatalk.com/d/13/01/14/jupusude.jpg (Insert the sounds of angels singing here) simply stick a quality screwdriver in between the teeth farthest to the passenger side and go back up top and tighten the pulley bolt to 90lbs (or whatever torque spec helps you sleep at night). Then... and this is the most important step in the whole thing REMOVE THAT SCREWDRIVER! While 90lbs of force will not break either the teeth or your best screwdriver, cranking the starter with that screwdriver in there probably will break something. Now go forth and enjoy a smoother ride to boost town! Link to comment Share on other sites More sharing options...
root_galaxy Posted January 14, 2013 Share Posted January 14, 2013 You want to do a write up on the rest of the steps to install this?? :-) Link to comment Share on other sites More sharing options...
BoostOrDie Posted January 14, 2013 Author Share Posted January 14, 2013 I'd love to. Should have time to get more pics tonight Link to comment Share on other sites More sharing options...
root_galaxy Posted January 14, 2013 Share Posted January 14, 2013 Awesome!!! You'd be my hero and many others on here as well! Link to comment Share on other sites More sharing options...
BoostOrDie Posted January 15, 2013 Author Share Posted January 15, 2013 0. Park your car on ramps if you have them, if not you can jack it up in step 10. 1.Disconnect negative battery cable. 2. Remove upper radiator hose. Note 1. I planned to remove the radiator fans, but the bolts holding the top of the fans to the radiator were rusted and I ended up cracking the radiator, so since it is not necessary to remove the fans I don't recommend it. 3. Remove the alternator and power steering belt. 4. Remove the a/c belt. 5. Remove crank pulley bolt. Here is a video of the way cool kids do that: here are photos of how I do it: Those items are a 3/8" socket extension, a random bolt, pry bar and my size 10 boot. 6. Wiggle the old crank pulley off making note of the location of the key. http://img.tapatalk.com/d/13/01/15/ajupu7eq.jpg 7. Set the new crank pulley on the end of the shaft and rotate it until the key lines up, then wiggle the pulley on to the shaft. 8. Place 2 small drops of gear oil on the threads of the crank pulley bolt Note 2. The oil helps get a true reading on your torque wrench. 9. Tighten the crank pulley bolt as tight as you can by hand. Note 3. Because the timing belt is still in place don't worry about spinning the crank, as long as you spin it clockwise, it's fine. Note 4. If you didn't disconnect the negative battery cable when you started, then do it now, otherwise when you go to start the car the crank position sensor value stored in the ECU won't match the actual crank position. 10. If your car is not on ramps, jack it up and place jack stands under the frame rails. 10.5 put your torque wrench, equipped with a 22mm socket, on the crank pulley bolt and rotate it so the handle of your torque wrench points to 1 o'clock. 11. Get under the car and locate your front differential drain plug http://img.tapatalk.com/d/13/01/15/gasy5eva.jpg 12. Peering between the differential and sub frame you will get a view of the flywheel. http://img.tapatalk.com/d/13/01/15/6e9esu2e.jpg http://img.tapatalk.com/d/13/01/15/eqyve2ud.jpg Note 5. When you go to tighten the crank pulley bolt it will rotate the bottom of the flywheel towards the passenger side of the car. 13. Place the tip of a long screwdriver in-between the the teeth of the flywheel farthest to the passenger side. http://img.tapatalk.com/d/13/01/15/aquty7a4.jpg Note 6. The weight of your torque wrench sitting at the 1 o'clock position should be enough to hold your screw driver in place, but if not, have a friend put some pressure on your torque wrench to pinch the tip of your screwdriver in place. 14. With your screwdriver in place you can tighten the crank pulley bolt and the transmission won't move. Tighten crank pulley bolt to 90lbs. Note 7. Tighten the bolt to whatever spec makes you happy. Perrin says 90lbs, so that's what I tightened mine to. Note 8. 90lbs of pressure will not break a tooth on your flywheel nor will it snap a quality screwdriver tip. 15. REMOVE THE SCREWDRIVER FROM YOUR FLYWHEEL! 16. Replace your ac belt. 17. Replace your alternator belt. 18. Reconnect your upper radiator hose. 19. Reconnect the negative battery cable. 20. If your car is jacked up lower it back down. 21. Top off your coolant. 22. Say a little prayer to the car Gods. 23. Turn your key to the 'on' position, wait for gauge sweep to finish, then start the car! 24. Bleed the air out of your cooling system 25. Go forth and drive fast! This modification was part of a series of mods I did to get rid of the feeling 'heaviness' the car had before boost. Together with a short ram intake that isolates a large cone filter in the passenger fender and a catless up pipe this modification makes in-town and all other 'off boost' situations much more enjoyable. http://img.tapatalk.com/d/13/01/15/dypu5ase.jpg Link to comment Share on other sites More sharing options...
root_galaxy Posted January 15, 2013 Share Posted January 15, 2013 Awesome, awesome, awesome!! I think we should sticky this or put it in the walk through section. Great job my friend!! You will be thanked many times =) Link to comment Share on other sites More sharing options...
Anarcan Posted January 17, 2013 Share Posted January 17, 2013 The Question is... How much do you love having one installed on your auto?? noticeable difference? Link to comment Share on other sites More sharing options...
BoostOrDie Posted January 17, 2013 Author Share Posted January 17, 2013 Yes, it is defiantly noticeable. I really enjoy the 'lighter' feeling the car has when not under boost. Link to comment Share on other sites More sharing options...
