Zombaru Posted October 9, 2015 Share Posted October 9, 2015 Its starting to get cool again and i can feel my oem 09 suspension stiffening up. Once it reaches -15C you could replace my suspension with solid welded bars and the bump harshness would be identical. it goes away With driving unless its below -25C Im not kidding. When its warm out its Fine. boaty and floaty Shocks seem fine no clunks or noises. Just once its cold a crack in the road becomes a dash bouncing crack. I have Pinks waiting for spring. i have no idea what causes this. i'm looking at HD's So, Suspension Gets mega stiff in the cold. Could it be From older shocks or something else? Any cold Weather Spec.B's for input? Thanks Link to comment Share on other sites More sharing options...
Zombaru Posted October 19, 2015 Author Share Posted October 19, 2015 After a bit of research it seems that there is a water build-up inside the bottom of the area where the insert goes. The fix seems to be to drill a hole (3/32) in the bottom of the hollow area to allow the water to escape. Has anyone else had to do this? Link to comment Share on other sites More sharing options...
