Brakeswap.com Performance Brake Kit for LGT INSTALLED on Outback XT
Scooby2.5
A couple of months ago I had upgraded my Outback XT to LGT calipers at all four corners. I used DBA4000 rotors, Hawk HPS pads, and Technafit brake lines with Motul 600 fluid.
I really liked this setup and it was night and day different than the insufficient stock Outback XT brakes. One of my objectives in going this route was to keep the stock Outback XT wheels. I didn’t want to spend a ton of money on a BBK and then have to purchase wheels on top of that so I decided on the LGT setup. Xenonk was tracking his car with these and so I thought these brakes would be just fine.
The improvements were very good but still had that factory brake, spongy-pedal-feel and it still took some time for the brakes to respond because of the sliding caliper design. I could feel the brakes start to grab sooner than my stock Outback XT setup and it really should have had these brakes to begin with since it's a turbocharged vehicle.
I then saw that Brakeswap.com had come out with a Wilwood kit for the LGT, and that it would fit under the stock LGT wheels. I inquired about this with Eric from Brakeswap.com and found he was wanting to have someone try this kit under the stock Outback XT wheels. So, I took him up on his offer and ordered the Wilwood LGT kit for my Outback XT.
Installation was straight forward and just as easy as the LGT brake swap I had already done.
Step One: I removed the two bolts holding the LGT brake caliper and bracket to the spindle:
http://inlinethumb24.webshots.com/44759/2902131290074087040S600x600Q85.jpg
Here is a picture with the LGT caliper removed:
http://inlinethumb50.webshots.com/22641/2155675130074087040S600x600Q85.jpg
Next, I bolted the Brakeswap Wilwood Caliper bracket to the spindle using the factory bolts. The bracket goes to the outside of the spindle- closest to the rotor.
http://inlinethumb29.webshots.com/8796/2567736330074087040S600x600Q85.jpg
I then bolted the Wilwood caliper to the newly installed bracket using the supplied spacers and bolts to center the caliper over the rotor. In this picture I tried to show how the spacer goes in between the caliper and the mounting bracket on the side opposite the rotor.
http://inlinethumb63.webshots.com/41598/2919095340074087040S600x600Q85.jpg
Here is a picture of it fully bolted on the spindle with the mounting bracket:
http://inlinethumb63.webshots.com/6910/2486721070074087040S600x600Q85.jpg
and another shot looking down from the top of the rotor:
http://inlinethumb11.webshots.com/42506/2020717510074087040S600x600Q85.jpg
then finally with the SS brake line installed:
http://inlinethumb40.webshots.com/31399/2008606500074087040S600x600Q85.jpg
I then bled the brakes doing the inner bleeder screw first then the outer screw. There are two bleeders on each caliper. It is important to do both as there was a lot of air coming out of each one when I performed the bleeding. One thing to note is the Wilwood bleeder is very small. It has a brass fitting inserted into the caliper and then the bleeder screw inserted into the fitting; use a ¼ inch wrench on the bleeder screw and not on the brass fitting when bleeding the brakes.
After bleeding, I put the wheels back on and performed the burnishing process according to Hawk.
Below are some pictures of the finished install with the wheels on. They are a very close fit, but they fit fine under the 17” Outback XT wheels, just as they did on the 17” LGT wheels.
My initial impressions of the kit are GREAT. Where the LGT upgrade for the Outback was much better, the Wilwood kit is much much better. There is a lot more pedal feedback than with the LGT brakes and they engage quicker. When the pedal is pressed ever so slightly, you can already feel them starting to brake. If you engage the ABS, they brake just as they did with the LGT brakes only much quicker due to needing less input from the pedal; a lot quicker reaction time, if you will.
If I were going to upgrade an Outback XT’s brakes again I would go straight to the Wilwood kit up front and just find some LGT calipers for the rear. (At least until Brakeswap.com comes out with a kit for the rear.) You will pay a bit more, but if you are already upgrading, you might as well purchase this reasonably priced kit from Brakeswap.com. You get a much better brake setup and they still fit under the factory wheels.
http://inlinethumb27.webshots.com/42906/2905336030074087040S600x600Q85.jpg
http://inlinethumb31.webshots.com/43550/2895365450074087040S600x600Q85.jpg
http://inlinethumb43.webshots.com/44010/2340574020074087040S600x600Q85.jpg
http://inlinethumb25.webshots.com/41688/2083973440074087040S600x600Q85.jpg
http://inlinethumb04.webshots.com/8387/2169126450074087040S600x600Q85.jpg
By the way I didnt put this in the review but man are these things light. Less than five lbs. I couldnt believe it when I pulled them out of the box. They feel like they are made from plastic but are actually some sort of aluminum alloy.
"Each body is stress-flow forged from premium grade aluminum alloy billets"
  • 1 year later...
  • 3 weeks later...
I just bought this kit from Eric for $999 and it's pretty awesome. He included braided brake lines for the rear calipers too.
The bad news is the OEM wheels on my 2008 Outback XT don't work. The wheel hits the caliper before it's totally on, and it wasn't even close. So I don't think spacers would work.
Looks like I need to find some wheels like gregnauman has.
It really sucks, I got one all mounted and bled, and then had to pull it right back off.
  • 4 weeks later...
I paid $999.
The kit included front 4 pot Wilwood Calipers, slotted rotors, Front Hawk HPS pads, mounting adapter, mounting bolts, and Braided brake lines for all 4 wheels.
contact eric at: brakeswap at gmail.com
Thanks! That is correct.
That is also $999 shipped. Those rotors are freaking heavy!
Free Sonax Cleaner Deal
http://www.brakeswap.com
Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol...
Great service. No bumping required :icon_tong!
  • 4 weeks later...
