987687 Posted January 12, 2011 Share Posted January 12, 2011 Ouch! that's terrible I'd be very sad if that happened to mie. Link to comment Share on other sites More sharing options...
TaSe Posted January 12, 2011 Share Posted January 12, 2011 145,xxx on the clock Link to comment Share on other sites More sharing options...
iluvdrt Posted January 15, 2011 Share Posted January 15, 2011 Just clicked over 220K. Can't wait for a 1/4 million LOL Link to comment Share on other sites More sharing options...
jagoulet Posted January 16, 2011 Share Posted January 16, 2011 My '95 Legacy wagon now has 229,000 miles. Runs fine, still using no oil. Mileage is down a couple of mpg so some fine tuning may be in order. I bought it with 119,000 on it. The only items I have replaced are: clutch, alternator,rear struts and gas tank filler pipe. Routine maintenance beyond that. The door locking system is still wacko and probably always will be - gives the car a little personality (even if scary!) LOL John Link to comment Share on other sites More sharing options...
Jippi Posted January 16, 2011 Share Posted January 16, 2011 171000 bought it with 168000 Link to comment Share on other sites More sharing options...
subikid90 Posted January 17, 2011 Share Posted January 17, 2011 My 97 and 01 LGT's are both just over 192k -Subikid90Â 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Zues Marine Posted January 22, 2011 Share Posted January 22, 2011 127,777! Link to comment Share on other sites More sharing options...
worknlikeadog Posted January 22, 2011 Share Posted January 22, 2011 250,000 on everything except tranny she/he only has 235,00 Link to comment Share on other sites More sharing options...
fiber_tek Posted January 22, 2011 Share Posted January 22, 2011 219,000 Â 2.2l 5-speed Link to comment Share on other sites More sharing options...
HuskiesGo Posted January 22, 2011 Share Posted January 22, 2011 Just rolled over 130K, bought it with 70K 3 years ago. Link to comment Share on other sites More sharing options...
troutman Posted January 24, 2011 Share Posted January 24, 2011 Bought it 3 weeks ago with 218,xxx. Replaced timing belt water pump idlers t stat spark plugs alt. & air cond belts tires. Hoping nothing else soon. Do have to look into why only gauges work with lights on and no other dash such as air and heat control. Link to comment Share on other sites More sharing options...
hippo325 Posted January 24, 2011 Share Posted January 24, 2011 Bought my sweet '98 Legacy GT wagon with 130K on it. The credit union asked NO questions..Except what color it was! Loaned with the statement.."You'll actually pay this off, before you get rid of it, cause it will still outlast the loan." They know me there. Last vehicle was a Jeep. Jeep math ($100 parts+ Chrysler engineering+ 240K miles= Losing battle) Subaru math ( $18 parts+ Fuji Heavy Ind engineering + 130K = WINNER!) I will drive this thing till gasoline is three jillion dollars per ounce. Link to comment Share on other sites More sharing options...
987687 Posted January 24, 2011 Share Posted January 24, 2011 I'm gonna hit 120k in my 96 on my way home from class today. Started right up and purred along like a kitten... a retarded kitten... in the -20 weather this morning. Had a couple backfires and almost stalled, but after a bit of warming up it acted normal again. Link to comment Share on other sites More sharing options...
subydrift Posted January 25, 2011 Share Posted January 25, 2011 My 97' Outback has 138k on it as of today. I replaced the head gaskets, t-stat, full gasket kit, t-belt, water pump, idler pulley, plugs, wires, air filter, oil & filter, and PCV about 500 miles ago. Mechanic that assembled the motor for me said the insides were really clean and she runs great now. Hopefully this motor will last a long time. It has a little piston slap on cold start ups but I let it warm up for ~5 minutes before I drive it and baby it until its warm so I don't think that will become a problem. I hope... Link to comment Share on other sites More sharing options...
limden3 Posted January 26, 2011 Share Posted January 26, 2011 Hi All, Newbie here w/'99 SUS. 212,243 miles . Bought it new w/26 miles on 12/22/98. Just had head gaskets done (212,111 mi) along w/ timing belt, water pump, oil pump, needed front drivers side wheel bearing and hub, and tie rod. Oh and set of Yoko TRZ's. First time I had to replace tie rod, bearings and hub, now that's what I call reliable!  216,800 Link to comment Share on other sites More sharing options...
98LGTLover Posted January 27, 2011 Author Share Posted January 27, 2011 Brought my $1,300 1998 LGT home! Engine runs great! It shakes on the highway though, I think the tires need to be rebalanced, get some struts, and an alignment and I'll be good to go  141,7XX miles Link to comment Share on other sites More sharing options...
subikid90 Posted January 27, 2011 Share Posted January 27, 2011 Do you still have the 96L also? Are you going to keep or sell the white one? -Subikid90Â 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
987687 Posted January 27, 2011 Share Posted January 27, 2011 Not sure if I mentioned it, but I had to replace an inner tie rod end to pass inspection. Wasn't a big deal, a little bit of a pita, but I got it done. Link to comment Share on other sites More sharing options...
98LGTLover Posted January 27, 2011 Author Share Posted January 27, 2011 The 96 L still has to get the engine swapped into it then it will be sold. The white one goes to my sister, and the black one in mine I drove it home from Coeur d' Alene (40 miles from my house), keep in mind this is the 4th time I've driven stick. I was happy to get home! I want to keep driving it all the time so I can get used to shifting and starting out. Pictures of the car tomorrow hopefully! Link to comment Share on other sites More sharing options...
subikid90 Posted January 27, 2011 Share Posted January 27, 2011 It takes a while but it will become second nature very soon lol. Then try to drive an auto again, it blows -Subikid90Â 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
98LGTLover Posted January 27, 2011 Author Share Posted January 27, 2011 Haha yeah, it was pretty bad at one stoplight.. I sat there the whole time it was green lol I was so pissed off... Then I realized I still had it in 3rd. I took off immediately after I got in back into 1st. Even though I'm not that great at driving stick yet I already like it a lot better than an auto! Link to comment Share on other sites More sharing options...
987687 Posted January 27, 2011 Share Posted January 27, 2011 Putting it into 3rd not 1st... classic. I do it sometimes in my GL because the bushings are SOOO shot. The stick moves back and forth in any gear as much as neutral the shifter bushings are so shot... Link to comment Share on other sites More sharing options...
98LGTLover Posted January 27, 2011 Author Share Posted January 27, 2011 Yeah that is how this car is! It is a little hard to push it into first too. One plus is that the car came with a Haynes Manual and I've been wanting one. Link to comment Share on other sites More sharing options...
987687 Posted January 27, 2011 Share Posted January 27, 2011 Yeah that is how this car is! It is a little hard to push it into first too. One plus is that the car came with a Haynes Manual and I've been wanting one. You shouldn't really be shifting into first when you're moving. 2nd is pretty low on these, most of the time if you're moving 2nd is fine. Link to comment Share on other sites More sharing options...
98LGTLover Posted January 27, 2011 Author Share Posted January 27, 2011 I don't shift into first while I'm moving... I saying when I put it into first when I go to take off again.. Link to comment Share on other sites More sharing options...
