GuamSTI Posted December 14, 2010 Share Posted December 14, 2010 Before: http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/SubieFront.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/RearQuarterGood.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/Loaded.jpg After a Shower: http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2838.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2843.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2845.jpg Link to comment Share on other sites More sharing options...
kaz98gt Posted December 14, 2010 Share Posted December 14, 2010 Looking good! Any more info on her? Miles, recent work, how long you've had it, etc? And just throwing it out there, is it just me or is the hood misaligned in the last photo? Link to comment Share on other sites More sharing options...
rshaw123 Posted December 14, 2010 Share Posted December 14, 2010 its the same way in the first photo too, maybe he had the hood popped off the first latch or something Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted December 14, 2010 Share Posted December 14, 2010 and btw if ur hood doesnt latch down all the way, look at the support right infront of the radiator, it might be bent outward or inward. Thats the problem I had with my hood(it wouldnt latch down all the way) but i found out that it was just that bar(very easy to bend) Link to comment Share on other sites More sharing options...
GuamSTI Posted December 27, 2010 Author Share Posted December 27, 2010 Thanks guys the hood has some damage in the front and the RH headlamp is also pushed in a bit. I have been doing some work on it and got the headlamp and grille aligned. Now the problem is the hood latch does not aling with the hood because of the damage to the hood. Do I fix the hood? replace it with a used one without the scoop? or get an OEM looking CF hood? the car has 139,000 miles, Automatic, the most of the bottom mechanical parts/bolts/lines, etc. has some rust on it including the struts and calipers. Bosy has the normal Legacy rust spots. In fact I broke 1 slide pin on the LH front caliper and currently trying to find a less expensive option to getting it fixed. Aside from torque bind the car runs fine. I was going to sell this after I fixed the brakes but I think I am falling in love with this one. http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2870-1.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2871.jpg Link to comment Share on other sites More sharing options...
GuamSTI Posted December 27, 2010 Author Share Posted December 27, 2010 http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2856.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2861.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2862.jpg Link to comment Share on other sites More sharing options...
Baddog Posted December 27, 2010 Share Posted December 27, 2010 and btw if ur hood doesnt latch down all the way, look at the support right infront of the radiator, it might be bent outward or inward. Thats the problem I had with my hood(it wouldnt latch down all the way) but i found out that it was just that bar(very easy to bend) Got a picture of the location of this? Link to comment Share on other sites More sharing options...
GuamSTI Posted December 27, 2010 Author Share Posted December 27, 2010 http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2860.jpg Link to comment Share on other sites More sharing options...
Zues Marine Posted December 27, 2010 Share Posted December 27, 2010 Got a picture of the location of this? its the bar with the hood latch on it, where you mount supertones Link to comment Share on other sites More sharing options...
GuamSTI Posted January 30, 2011 Author Share Posted January 30, 2011 http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2957.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2959.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2994.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_2992.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_3031.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_3034.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_3037.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_3039.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_3041.jpg http://i190.photobucket.com/albums/z290/jgrsevilla/98%20Legacy%2025%20GT/IMG_3038.jpg Link to comment Share on other sites More sharing options...
GuamSTI Posted January 30, 2011 Author Share Posted January 30, 2011 Now after all this work maybe somebody can give me an idea how to open the sunroof manually so I can clean off the drain hoses (it floods on the front passenger footwell). My sunroof does not slide back it pops up only. There is no click at all or the sound of a motor when I try to slide it back. I am thinking I should check a fuse or relay first. Any idea where this things are located? Thanks, Link to comment Share on other sites More sharing options...
kaz98gt Posted January 31, 2011 Share Posted January 31, 2011 You need to pop the headliner off to get to the drain hoses. Either one is clogged with debris or it shrank over the years and pulled away from the plug attachment. I hear it's a bitch to get the headliner off, but it's definitely doable. Good luck. Link to comment Share on other sites More sharing options...
subikid90 Posted January 31, 2011 Share Posted January 31, 2011 Its just a lot of screws lol. Take me about 30 mins now. Dang that looks like you did a good job on the repairs and paint. You do it all yourself? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
GuamSTI Posted February 1, 2011 Author Share Posted February 1, 2011 Yes, not much problems with the body it was all original Link to comment Share on other sites More sharing options...
knesmomax Posted February 3, 2011 Share Posted February 3, 2011 Nice legacy man. I'm definitely liking the wheels. They remind me of my old Impreza. Link to comment Share on other sites More sharing options...
daleyswanson Posted February 3, 2011 Share Posted February 3, 2011 Its just a lot of screws lol. Take me about 30 mins now. Its really not too bad. Taking all of the upper trim pieces off without breaking the tabs was the hardest part. Aside from putting the bitch back in by yourself Link to comment Share on other sites More sharing options...
GuamSTI Posted February 8, 2011 Author Share Posted February 8, 2011 I am now in MD I just heard from my wife on Guam that the LGT just started smoking on the right front part of the car. I am hoping it did not overheat or there goes a head gasket. I told her to not drive the car until I get back. Now just in case I need to replace or fix the motor what do you guys think is a better investment in terms of money and time? 1. Rebuild the original motor? 2. convert to a JDM Turbo motor? 3. convert to a WRX motor? 4. covert to an STI motor? 5. convert to an 07' and up NA motor? Thanks, Link to comment Share on other sites More sharing options...
subikid90 Posted February 8, 2011 Share Posted February 8, 2011 JDM tubro motor , sti (besides 04) and anything 07 and up will be a wiring nightmare. I was if you want boost put a 02-03 wrx motor or 04 sti motor in. If you want something that just runs then rebuild the original motor. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
GuamSTI Posted February 8, 2011 Author Share Posted February 8, 2011 My worry about rebuilding the original motor is reliability of the head gaskets. I do not really like a Turbo motor because I would not like to replace the transmission. The reason I bought the LGT is because I wanted an automatic car. Link to comment Share on other sites More sharing options...
kaz98gt Posted February 8, 2011 Share Posted February 8, 2011 New headgaskets shouldn't be an issue; felpro makes a great set of gaskets that are higher quality than the OEM ones, and (even though subaru said that they beefed up replacement gaskets for their 2nd gen 2.5s) I'd go that route if anything. A lot of people have said great things about the felpro headgasket kits. Link to comment Share on other sites More sharing options...
subikid90 Posted February 8, 2011 Share Posted February 8, 2011 I have fel-pro gaskets in my white subi and have had no problems for about 20k now. I have them sitting in my garage for my black car also. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
GuamSTI Posted February 9, 2011 Author Share Posted February 9, 2011 Okay, thanks I will just replace the head gaskets if they are bad. Link to comment Share on other sites More sharing options...
