DRL DISABLE leads to unFunctional Windows?
  • Replies 58
  • Created
  • Last Reply
Try the window lockout button on the drivers door first(probably hit it with an elbow getting in or out. If that's not it then check the connections under the dash and make sure only the white one is unplugged.
Let's kick this pig!
I assume you plugged them back in and everything worked Properly?? If not I would try that, I have disabled mine and the windows work fine and they have been disabled for about 6 months. Good luck to you
I plugged it all back in and everything worked just fine! this made me angry!
No reply from the OP.
Must have been the window lock.
:hide:
it actually wasn't thank you very much! I just havent had time to get back to my PC! no need to assume things! It was just awkward that my windows would not go up or down!
