kbear Posted April 10, 2013 Share Posted April 10, 2013 Am starting to research getting another subby, can i get some opinions on which model and engine type is the most dependable? Thanks, looking forward to your responses. Link to comment Share on other sites More sharing options...
dmanaenk Posted April 10, 2013 Share Posted April 10, 2013 subaruoutback.org 666 Link to comment Share on other sites More sharing options...
flygtfly Posted April 21, 2013 Share Posted April 21, 2013 Any non-turbo car would be more reliable than the turbo car but if you want the turbo you want the turbo. If you do get a turbo make sure you remove the filter in the feed line to the turbo. Subaru issued a service/tech bulletin #02-106-08R that you can Google. It recommends replacing the filter but you don't need it so just remove it. The diffs need regular maintenance so just make sure its been done. Good luck! Link to comment Share on other sites More sharing options...
