whiteline 20mm rsb clunk
cypher0117
I have had my whiteline 20mm rsb installed with kartboy endlinks for 5 days and I am getting clunking/smacking of metal on metal. I have noticed that my rear lower lateral link (toe adjustment arm) is coming in contact with the swaybar. Paint is already warn through to metal. My car is lowered .8" in the rear with eibach pro kit. What would be the easiest way to fix this issue and has anyone had to deal with this before with the same/similar setup?
Thanks!
Uh oh... I just order the same set up.... Will my issue be the same as on a '12 LGT? Would I need that kit too?
I put my stock endlinks back on and the noise is gone. Might be getting the klc144 adjustable endlinks. Trying to decide if those are worth waiting 3 weeks for the $50 cheaper avo adjustable endlinks to get back in stock.
You shouldn't need the kta124 kit. I got that because I bent one of my lateral links and threw my alignment out of spec
