subaruowner840 Posted September 28, 2005 Share Posted September 28, 2005 I recently bought a 2005 Legacy 2.5GT. I've owned it about 3 months and put about 5k miles on it. Lately I've been noticing the transmission shifts rough between 2nd and 3rd gear. When I'm accelerating moderately (RPM's around 3k) and the car shifts from 2nd to 3rd gear (i have the 5 speed automatic transmission) the whole car seems to shake or shutter. Sometimes its mild, sometimes more dramatic. This never happens when shifting between other gears, nor does it happen when I accelerate hard or slowly. Could this have something to do with the AWD or transmission? This is my first Subaru and maybe there are some wierd vibrations/shutter as part of the AWD system distributing torque and I just need to get used to it. I still have plenty of time left on my warrenty, however, if this is a serious problem in the making I want it fixed ASAP. Any ideas? Link to comment Share on other sites More sharing options...
melayout Posted September 28, 2005 Share Posted September 28, 2005 It started at 15k and it still does it at 35k with the same intensity, so it doesn't look like it's getting worse. I've reliably reproduced it to the dealer twice and the last time the Tech rode with me and hooked up the Subaru Select Monitor to see what the transmission is doing. We found out that right after the 2nd->3rd shift the Torque Converter locks up and that's when the hard shake/shutter occurs. The Tech relayed that the Tech Line and District Rep say that this is normal for the Torque Converter to cause a harsh shake but that's un-f$cking-acceptable. My service manager is setting up a 1-on-1 appointment with the District Rep so I can reproduce, express my disappointment and discuss how this will be resolved. If they can't/won't solve it, I'll either have SoA pay someone else to fix or I'll fight to Lemon it. Mods, please don't move this thread, I would like it get as much visibility as possible. I keed I keeed Link to comment Share on other sites More sharing options...
kiem Posted September 28, 2005 Share Posted September 28, 2005 Mine doesnt do that yet. knock on wood. Sorry to barge in here. For mine, I notice today the tranny didnt upshift until the RPM went over 4K. It did this while going from 1st to 2nd then from 2nd to 3rd gear. I wasnt flooring the pedal or anything - it was steadily acceleration. This is the second time this happened - dont know if anyone experience the same thing. Link to comment Share on other sites More sharing options...
subaruowner840 Posted September 28, 2005 Author Share Posted September 28, 2005 Ya, I noticed the same thing. It will do that from time to time. Not sure, correct me if I'm wrong, but the 5eat will adjust to the way you drive and when cornering. Sometimes the tranny/computer will think you're driving more aggresive and hold the gear a little longer - even if you're not in sport mode. Let's not get off the subject though, still trying to find the answer to my shutter/shaking problems. Link to comment Share on other sites More sharing options...
agctr Posted September 29, 2005 Share Posted September 29, 2005 Usually depending on when yr service interval is, I have noticed on my MY01 that the shifts can be a little strange and do hold a little longer than usual. If this is causing u great concern, just call yr SA on the phone and ask them before taking the GT in. Let us know how you go as Im sure there would be a lot of parties in the same boat. Ada///M. Link to comment Share on other sites More sharing options...
melayout Posted September 29, 2005 Share Posted September 29, 2005 agctr, The holding of gears is not an issue but a feature of the transmission since it is equipped with a G-sensor to determine when you're taking a turn and therefore holds the gear longer. The issue is an excessive shock coming right at the 2nd->3rd shift in D, Sport or Manumatic mode under light to WOT acceleration. Will piss you off especially in light stop-and-go traffic. I keed I keeed Link to comment Share on other sites More sharing options...
triniexr Posted September 29, 2005 Share Posted September 29, 2005 I have that problem in 2nd->3rd, also have trouble getting it into reverse sometimes. I would have to make the car move a bit then put it in reverse. Link to comment Share on other sites More sharing options...
melayout Posted September 29, 2005 Share Posted September 29, 2005 triniexr, you're having problems with Reverse on the 5EAT? I keed I keeed Link to comment Share on other sites More sharing options...
triniexr Posted September 29, 2005 Share Posted September 29, 2005 triniexr, you're having problems with Reverse on the 5EAT? If 5EAT means manual then ya. It really pisses me off, I took it to the dealer already and they just bleed the clutch but it still happens. Link to comment Share on other sites More sharing options...
eles1 Posted September 29, 2005 Share Posted September 29, 2005 If 5EAT means manual then ya. It really pisses me off, I took it to the dealer already and they just bleed the clutch but it still happens. 5EAT = 5 speed Electronic Automatic Transmission Your issues going into reverse on the 5MT are somewhat common and probably not a cause for concern. Since there is no synchro for reverse, it's a little difficult to engage sometimes. Link to comment Share on other sites More sharing options...
melayout Posted September 29, 2005 Share Posted September 29, 2005 The 5EAT is the 5-speed automatic, the 5MT is the manual. So your problems are on the 5MT and not the 5EAT, which what this thread is about. As for the issue of a shock on the 2nd->3rd shift on the 5MT, it's the rear differential popping/whining about it. Just ease/smooth out your shifting to avoid that. Try to shift after torque has peaked. As for your issue with reverse, just double-clutch or shift into 1st or 2nd first, then reverse. Now back on-topic, again the issue is an excessive shock right at the 2nd->3rd shift on the 5-speed automatic transmission. I keed I keeed Link to comment Share on other sites More sharing options...
bdisco Posted September 29, 2005 Share Posted September 29, 2005 The issue is an excessive shock right at the 2nd->3rd shift on the 5-speed automatic transmission. I think mine may have done this once. Was more like a stutter though, car bucked a bit like stuck between boost and vac. Maybe I'm just paranoid from reading these post. Link to comment Share on other sites More sharing options...
Rommel Posted September 29, 2005 Share Posted September 29, 2005 This happened to me last night from a stop. I thought I was on manumatic 1 but I was on D because it didn't shift until around 4k and I was on gradual acceleration. Link to comment Share on other sites More sharing options...
TYNY Posted September 29, 2005 Share Posted September 29, 2005 only 1500 miles so i haven't had ths shudders - only when i pee. just kidding but i hope i make you guys laugh. i have had the holding-revs-higher-than-wanted-not-in-sport-mode thing though. guess the car is anticipating aggressive acceleration? Link to comment Share on other sites More sharing options...
agctr Posted September 29, 2005 Share Posted September 29, 2005 So is it like a real sort of bang and hard shift for 2nd to 3rd ? Ada///M. Link to comment Share on other sites More sharing options...
melayout Posted September 29, 2005 Share Posted September 29, 2005 agctr, Yup. I keed I keeed Link to comment Share on other sites More sharing options...
agctr Posted September 29, 2005 Share Posted September 29, 2005 I get that sometimes when Im on and off the loud pedal really quickly but otherwise its fine. And I know this is totally different but it must be similar to the SMGII shifts in the M3 which are very hard but this happens in most gears in modes S4 S5 & S6 so I do know what you mean. Could it be a low level of fluid in the tranny prehaps ? Just a thought ? Ada///M. Link to comment Share on other sites More sharing options...
melayout Posted September 29, 2005 Share Posted September 29, 2005 When I rode with the Tech, using the Subaru Select Monitor we narrowed it down to the engagement of the torque converter lockup clutch that always occurs on the 2nd->3rd shift. I keed I keeed Link to comment Share on other sites More sharing options...
Rommel Posted September 29, 2005 Share Posted September 29, 2005 mine is from 1st->2nd Link to comment Share on other sites More sharing options...
melayout Posted September 29, 2005 Share Posted September 29, 2005 My shock occurs with light-full throttle in D, Sport and Manumatic mode at the 2nd->3rd. Others, does it also occur in light-full throttle and all drive modes? I keed I keeed Link to comment Share on other sites More sharing options...
Rommel Posted September 29, 2005 Share Posted September 29, 2005 mine occures on a steady throttle, seems like its waiting for something before it shifts Link to comment Share on other sites More sharing options...
AWD-Turbo Posted September 30, 2005 Share Posted September 30, 2005 I haven’t had any problems with mine in 10k miles. For any of you who are experiencing problems, have you checked your transmission fluid level and/or quality? I think the recommended ATF change interval is fairly long. I’m probably going to get mine at least drained and filled after 2 years. Link to comment Share on other sites More sharing options...
agctr Posted September 30, 2005 Share Posted September 30, 2005 melayout, mine is like yrs to be honest, when you hop on it and get off real quick, think its all about being smooth. I kick myself everytime I do it. Sounds like its a common think cause mine in a MY01....... Ada///M. Link to comment Share on other sites More sharing options...
melayout Posted September 30, 2005 Share Posted September 30, 2005 agctr, I'm not hopping on it and getting off real quick. E.g. 1. I'm stopped at a light 2. 5EAT in Normal D mode 3. Light turns green and I tip in(30%) or go WOT(100%) on the throttle 4. 1st->2nd shift happens smoothly 5. Still at partial throttle(30%) or WOT(100%) 6. 2nd->3rd shift happens with a big and loud shock that shakes the whole car 7. Still at partial throttle(30%) or WOT(100%) 8. 3rd->4th shift happens smoothly just like 1st->2nd To avoid the shock, I have to totally lift off the throttle right before it shifts so that the least amount of torque is going thru the transmission. I keed I keeed Link to comment Share on other sites More sharing options...
eamiller Posted September 30, 2005 Share Posted September 30, 2005 I haven’t had any problems with mine in 10k miles. For any of you who are experiencing problems, have you checked your transmission fluid level and/or quality? I think the recommended ATF change interval is fairly long. I’m probably going to get mine at least drained and filled after 2 years. Actually, the recommended interval is (30mo) 30k for ATF ((15mo)15k for severe duty schedule). The ATF plays a huge part in the operation of an automatic transmission and the torque converter. In addition, it is subjected to amazing amounts of shearing and heat stress. If I encounter an AT with harsh shifting, the first thing I would do is change the ATF to see if it makes a difference. The way a lot of us drive our Legacies, it's important to follow the severe service schedule. Link to comment Share on other sites More sharing options...
