Trunk lid
The FSM make it sound like you do everything from outside the car, but it might be easier to remove the liner to pinch the plastic pop-it's out. I've never removed this piece myself so I'm not sure. I do know that I prefer to push pop-it's out from the inside whenever possible.
This thread has more pictures too
http://legacygt.com/forums/showthread.php/anyone-know-remove-trim-strip-above-rear-license-plate-sedan-56627.html
Remove the plate, there should be a couple bolts visible remove those. Then it is just held in via clips. They will probably be stiff since these cars are old now.
