DR.1337 Posted May 17, 2011 Share Posted May 17, 2011 So my front right strut is bent and thus I need to replace it. My dad tells me that its a pain in the butt to just replace the strut, thus having to remove the coil and whatnot off of the defective one. He told me just to buy the entire assembly. My question is, could I just get a new strut and fit the coil over it or should I just go for an entire assembly. Also are their alternatives to the dealer? Link to comment Share on other sites More sharing options...
underground000 Posted May 17, 2011 Share Posted May 17, 2011 Just rent a coil compressor from autozone or somewhere. Save the money and just buy the strut, but a rule is to replace both front not just one 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 17, 2011 Share Posted May 17, 2011 Get replacement struts from Tire Rack or one of our local vendors. The KYB GR2 is a good replacement. It is not a pain in the butt to just change out the strut. As proof, you can't buy an assembled strut from the dealer. If you are nervous about swapping the spring, just remove your front struts, bring them to a shop, and pay them to swap the springs to your new struts. Remember to get an alignment!!! [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
xero287 Posted May 17, 2011 Share Posted May 17, 2011 remember to get an alignment!!! +1 Link to comment Share on other sites More sharing options...
WhiskeyTango Posted May 17, 2011 Share Posted May 17, 2011 Get replacement struts from Tire Rack or one of our local vendors. The KYB GR2 is a good replacement. Can you use the stock top hats with thoes? http://www.tirerack.com/suspension/Susptabl.jsp?autoMake=Subaru&autoModel=Legacy+Sedan+2.5+GT&autoYear=2005&autoModClar=Base+Model Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 17, 2011 Share Posted May 17, 2011 With GR2's? Yes. The only time you have to swap top-hats is if you are going to use Bilsteins, and even then you might not HAVE to. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
DR.1337 Posted May 17, 2011 Author Share Posted May 17, 2011 Get replacement struts from Tire Rack or one of our local vendors. The KYB GR2 is a good replacement. It is not a pain in the butt to just change out the strut. As proof, you can't buy an assembled strut from the dealer. If you are nervous about swapping the spring, just remove your front struts, bring them to a shop, and pay them to swap the springs to your new struts. Remember to get an alignment!!! Ok well I'm going to get both. They don't need any kind of height adjustment right? Link to comment Share on other sites More sharing options...
sheppo9 Posted May 18, 2011 Share Posted May 18, 2011 I bet there is more bent than just the strut. Link to comment Share on other sites More sharing options...
WhiskeyTango Posted May 18, 2011 Share Posted May 18, 2011 With GR2's? Yes. The only time you have to swap top-hats is if you are going to use Bilsteins, and even then you might not HAVE to. For the GR2's do the stock spring work? Link to comment Share on other sites More sharing options...
mwiener2 Posted May 18, 2011 Share Posted May 18, 2011 For the GR2's do the stock spring work? yes i bet there is more bent than just the strut. +1 My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
DR.1337 Posted May 18, 2011 Author Share Posted May 18, 2011 I bet there is more bent than just the strut. I went in for an alignment and took a good look at it. I was told that the alignment couldn't be done because the strut is bent. Anyway, you can tell because there is a negative camber on the wheel. If there is more then just the strut, oh well, I have no choice but to replace whatever needs replacing. Link to comment Share on other sites More sharing options...
xero287 Posted May 18, 2011 Share Posted May 18, 2011 Well....let's hope it's just the strut. Link to comment Share on other sites More sharing options...
DR.1337 Posted May 31, 2011 Author Share Posted May 31, 2011 Well....let's hope it's just the strut. Well sure enough it was just the strut. Pulled it and replaced it yesterday. Thanks everyone for your input. Link to comment Share on other sites More sharing options...
