drndrn Posted February 24, 2011 Share Posted February 24, 2011 So i've read on another forum that someone is considering an engine swap in his Gen4 legacy. Well it's not actually his car, but he has the chance to buy an engine damaged but shell wise still good legacy 2.5i for less than $10,000AUD. So he was considering dropping an EZ30R into this shell instead of actually buying a 3.0R, which still go for approximately $30,000AUD. (yes cars are extremely expensive here in Australia) Anyways this conversion actually has me interested as a potential project too and was wondering how hard it would be, if I were able to source a complete engine, manual ECU and harness? Would I be correct in assuming that it would be plug and play considering the engine is being put into a car thats almost the same as the original car? I mean, all the sensors and what not would be the same if not similar correct? I've also heard talk of immobilizer issues, does anyone know how to by pass this issue? I'm guessing a dealer could do it as I'm sure they've seen engine/ecu transplants before in damaged cars and would have some way to reprogram a key for the car or something. Any help would be appreciated. Darren. Link to comment Share on other sites More sharing options...
Osei Posted February 25, 2011 Share Posted February 25, 2011 Tis not a plug and play. The ECU is different The wiring is different. The exhaust is different. The EZ30R donor may have had VDC.which the 2.5I doesn't. Waiting for someone else to add to the list. O. Link to comment Share on other sites More sharing options...
drndrn Posted February 25, 2011 Author Share Posted February 25, 2011 I know they're different, but if I'm able to get the ecu, wiring loom and engine from the same car. Would t work? Link to comment Share on other sites More sharing options...
Envy Posted February 25, 2011 Share Posted February 25, 2011 youd need to merge the harnesses... plus since the 3.0 is a 6 cylinder you might have some stupid clearence issues. id suggest getting a whole front clip not just the motor/harness Link to comment Share on other sites More sharing options...
Drift Motion Posted February 25, 2011 Share Posted February 25, 2011 why not just import one from Japan? since AUD almost = USD now days? Link to comment Share on other sites More sharing options...
drndrn Posted February 25, 2011 Author Share Posted February 25, 2011 As stupid as it sounds, I'd like to keep the car but only change the motor. I know for a fact there will be no clearance issues and any EJ series transmission will bolt right up to it. So the idea of just replacing the ECU's and harnesses isn't going to work? lol. Link to comment Share on other sites More sharing options...
