mmmmspecb Posted July 29, 2010 Share Posted July 29, 2010 Did anybody else notice the dramatic difference between Cobb's quoted HP gains on the 05-06 legacys vs. the 2007 legacys? 2005-2006 Stg 1 16% HP increase 22%TQ increase Stg 2 22%HP 38% TQ 2007-2009 Stg 1 4%HP 9%TQ Stg 2 6%HP 22%TQ Is this true? I'm going to be buying an 07' soon, so it's kind of strange to me that these numbers are so different. From what I know, the only difference between the 2006 and 2007 motor wise, is that the 2007 doesn't have a cat in the up-pipe, and it uses the vf-46 turbo which is supposed to be slightly better... Link to comment Share on other sites More sharing options...
MadMontie1 Posted July 29, 2010 Share Posted July 29, 2010 The simple answer is yes, the longer answer is a more detailed yes with Cobb's numbers correct Link to comment Share on other sites More sharing options...
HansGT Posted July 29, 2010 Share Posted July 29, 2010 05-06 have a cat in the up...07+ have a catless up and air pump. Also, oem base maps can vary by model year. 05-06 see higher % gains...'07+ are just better out of the box. In the end both peak numbers are nearly identical. Link to comment Share on other sites More sharing options...
