kai-wun Posted August 12, 2011 Share Posted August 12, 2011 Hey All, I've looked through the JDM suspension page and it seems quite good, but I'm wondering if I can do something similar (or better?) with a "custom" setup for a weekend autoX/HPDE car that's also a daily. Anyone have any recommendations as to spring rates to start with; if I do not want to run aftermarket sway bars at all? (I'd rather run _NO_ swaybars at all; but since it's a daily driver, I'm kinda worried about that). Of course, with only stock sway bars; I will need the springs be stiffened to compensate. I'll likely be running Dunlop Direzza Z1 Star Spec or Hankook RS3, so only sticky summer rubber; no r-comps) I understand Swift springs can be custom ordered; and Bilstein HD can be custom-valved to match the springrates? Thoughts? Link to comment Share on other sites More sharing options...
bmx045 Posted August 12, 2011 Share Posted August 12, 2011 from what I heard, 9k spring rates are the way to go without sways. I'm wanting to do a similar setup as you. Link to comment Share on other sites More sharing options...
whitetiger Posted August 12, 2011 Share Posted August 12, 2011 I am currently running no front sway bar and stock rear bar on 11.5K front / 12.5k rear spring rates with my ast4100 coilover setup. definitely very streetable. you will want a height adjustable setup since stiffer springs will make the car sit higher it they are all the same height un-sprung. Link to comment Share on other sites More sharing options...
