levihamernik Posted February 26, 2013 Share Posted February 26, 2013 So earlier today I was taking a corner on an snow packed road near my school. When I turned I last control and ran up onto the sidewalk. I hoped out and every thing looked and sounded fine. Then driving down the road I noticed that my steering had become really loose and sloppy. Then I noticed that I had to hold the wheel at about a 60 degree angle in order to keep it going in a strait line. So what exactly did I break and how much is it going to cost to have to fix? Link to comment Share on other sites More sharing options...
pleaidestar Posted February 26, 2013 Share Posted February 26, 2013 There are a few things that could have happened, bent control arm, tweaked knuckle, rack and pinion rod end could be bent. You have to do a visual check before anything else can be determined on cost or labor..could cost 100 bucks or 1000 or more, just got to figure out whats damaged. Link to comment Share on other sites More sharing options...
mailman Posted February 26, 2013 Share Posted February 26, 2013 Get under there and check it out, see if anything is obviously bent or broken. If you just need to replace the control arm or something it's not that hard to do it yourself and you can pick up a used one for probably no more than $50 at a junkyard. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted February 26, 2013 Share Posted February 26, 2013 Yeah. Sounds like you'll be able to answer this yourself as soon as you take a look under the car... Link to comment Share on other sites More sharing options...
gergeek Posted February 27, 2013 Share Posted February 27, 2013 you probably also snapped the swaybar link Link to comment Share on other sites More sharing options...
levihamernik Posted February 27, 2013 Author Share Posted February 27, 2013 so here are some pictures. nothing looks bent or broken. but then again i dont know exactly what i'm looking for. is it possible it just threw the wheels way out on alignment? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted February 27, 2013 Share Posted February 27, 2013 This might just be because your wheel is turned, but your left front sway-bar link looks to be an in awfully awkward position... What side of your car slid into the curb? Link to comment Share on other sites More sharing options...
travgag Posted February 27, 2013 Share Posted February 27, 2013 also i noticed your boot on the rack inst attached, or ripped, the one that covers the inner tie rod, if there play with the car running or off, you can rock the steering wheel back and forth to see if theres lots of play in the rack/ inner or outer tie rods. Or even better and for ball joints jack up the front end and check, Link to comment Share on other sites More sharing options...
colby Posted February 27, 2013 Share Posted February 27, 2013 have a friend bring the wheel back and forth with the car off and inspect for play. Link to comment Share on other sites More sharing options...
