lt1xlr8 Posted January 7, 2014 Share Posted January 7, 2014 Long story short my 09 legacy wore out a set of tires in 35k. Took it in to dealer and had it investigated along with 90k mile service, timing belt, the brake line and cat recalls also. The cause was found to be alignment for the tires and two rear sway bar bushings needed replaced. After the fourth trip back the alignment was fixed however there is a loss of power and fuel mileage is down 10 mpg. The dealer claims there is nothing wrong with the car however it drove perfect before they had their hands on it this time. Anyone else out there have problems like this after the cat recall? Changed the spark plugs since and that was not the problem. Link to comment Share on other sites More sharing options...
apexi Posted January 7, 2014 Share Posted January 7, 2014 What is your average mpg if you're down 10mpg? I didn't have any problems after the recalls. Link to comment Share on other sites More sharing options...
lt1xlr8 Posted January 8, 2014 Author Share Posted January 8, 2014 Was 32-33 now 22-24 Link to comment Share on other sites More sharing options...
apexi Posted January 8, 2014 Share Posted January 8, 2014 33-35 sounds very unusual and 22-24 sounds normal. My car says I'm averaging 21.3mpg right now, but I typically average 22-25mpg. Keep in mind the 2009 legacy 2.5i SE has the following EPA mpg estimates: A/T model 20 city/26 highway/ 22 combined. M/T model 20 city/27 highway/ 22 combined. Link to comment Share on other sites More sharing options...
uptown4784 Posted January 15, 2014 Share Posted January 15, 2014 33-35 sounds very unusual and 22-24 sounds normal. My car says I'm averaging 21.3mpg right now, but I typically average 22-25mpg. Keep in mind the 2009 legacy 2.5i SE has the following EPA mpg estimates: A/T model 20 city/26 highway/ 22 combined. M/T model 20 city/27 highway/ 22 combined.  Yeah I get the same thing aroudd 21.3. I thought these cars would get better MPG, but I do drive fast Link to comment Share on other sites More sharing options...
lt1xlr8 Posted January 17, 2014 Author Share Posted January 17, 2014 Think it may be a combination of things. The timing belt was replaced when it was in for service and all the fluids were replaced (differential, transmission). Plus the winter gas, and reprogram. I got fuel at a different place Bp to be exact and averaged 30 mpg. Also not sure if anyone knows how many miles before the suspension wears out? I think my rear is shot because when I shift the car lunges forward and then squats the rear when I let out the clutch. Under normal acceleration Link to comment Share on other sites More sharing options...
NickB34 Posted January 17, 2014 Share Posted January 17, 2014 They should have been able to tell you if your struts were leaking... mine only lasted about 60k before leaking. By 90k, you should have them replaced... unless you're like most americans and don't care about the performance of your vehicle. Link to comment Share on other sites More sharing options...
lt1xlr8 Posted January 17, 2014 Author Share Posted January 17, 2014 Well I still have warranty left and they are covered but what do I do about the dealer saying they are OK? Link to comment Share on other sites More sharing options...
NickB34 Posted January 17, 2014 Share Posted January 17, 2014 Can't do much if the dealer won't play. You would have to get another mechanic to diagnose. What warranty do you have that covers struts?? Link to comment Share on other sites More sharing options...
lt1xlr8 Posted January 19, 2014 Author Share Posted January 19, 2014 Not sure what warranty I have but it has a 100 dollar deductible. Covered a coil pack and plug wires also the sway bar bushings. When I bought the car it had 23k on it in Nov. 2010 and this warranty covers 5 yr or 100k so I only have about 4k left to figure this out. I think I'm going to contact another dealer and see if they will honor my warranty and if they will have them check it out. Thanks for all the help everyone Link to comment Share on other sites More sharing options...
T_Altland27 Posted February 6, 2014 Share Posted February 6, 2014 Wow not to get off topic but in my 09 I have the 5 speed m/t and I get 33 mpg highway and 24 city eight now I'm averaging 27 mpg Link to comment Share on other sites More sharing options...
DonnyJagaru Posted February 6, 2014 Share Posted February 6, 2014 My 2.5i gets 700km/435miles per tank in the summer. That's an average of 25.7 mpg (US gallon). Not that marvelous really, but I gather others are getting worse. Link to comment Share on other sites More sharing options...
