dingbang Posted June 29, 2010 Share Posted June 29, 2010 I may end up breaking my 5MT doing this, but ever since I install my ACT clutch, my transmission likes to seep gear oil...from what I can determine, it's due to a failing input shaft seal. I don't wish to shell out the money to take the car to a tranmission shop since I can devote a weekend to this (and help from a mechanic friend in case I get myself into trouble)... My local dealer is crap so I don't even want to deal with them-I'm looking for part numbers for the following pieces for the tranny: front seal (input shaft seal) front/middle input shaft bearing (don't think i need to replace this, but would rather have it and not need it than the other way around) main transmission gasket 2 rear gaskets (think there are two rear covers, correct me if i'm wrong) axle seals rear output seal a local guy recommended new crush washers for neutral/reverse switches...and it coincides with some dude who made a walkthrough of this. any other misc parts anyone thinks i would need? Have a new pilot bearing on standby already. This is not a full rebuild of the transmission--just pulling it to crack the case and deal with the input shaft (leaving the majority of the internals intact and untouched)... TIA, Andrew Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2010 Share Posted June 30, 2010 Contact the guy's at fredbeans.com they will have everything you need. So the vendor forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
