Moderators BarManBean Posted April 6, 2012 Moderators Share Posted April 6, 2012 Thinking about buying a WBO2 sensor. If I do will I be able to easily plug it into the downpipe and then directly into my laptop for logging or is it more complicated than that? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Spec B Posted April 6, 2012 Share Posted April 6, 2012 The innovate lm1 or lm2 are the simplest (and portable) ones. Sensor runs from bung to a control box that is about 8"x4" that is powered via a plug that plugs into lighter, control box has the output that runs to you laptop. The other wbo2s I believe have some wiring involved..but are much more discreet. I have my lm1 in my glovebox powered by the cigarette lighter in the center armrest (all wires hidden). Been working fine for about 4 years now. Link to comment Share on other sites More sharing options...
bmx045 Posted April 6, 2012 Share Posted April 6, 2012 My AEM UEGO is the boss. it's easy to wire and has a signal cable and all you do is get an rsr232 serial plug from radioshack and plug the wire into it, with a ground, and romraider will integrate the signal. Link to comment Share on other sites More sharing options...
robitrice Posted April 6, 2012 Share Posted April 6, 2012 I got the LC1 and its not bad. I am always scared about wiring but it was not that bad. has two auxillary outputs that you can connect into your laptop and it comes with the software. Alot of people have disliked the LC1 but i have yet to have a problem with it. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 7, 2012 Author Moderators Share Posted April 7, 2012 Well, that was quick. Found this on CL down the road and called it done. Hopefully everything plugs ups and works as it should. Off the the exhaust shop next week to get a bung welded in... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
robitrice Posted April 7, 2012 Share Posted April 7, 2012 nice setup! Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 7, 2012 Author Moderators Share Posted April 7, 2012 Yeah, So far I was finding LC1s for around $100, paid the same for this one so hopefully it's a good deal. Bought if from a guy who was using it to run NOS on his mustang...? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
mwm5094 Posted April 7, 2012 Share Posted April 7, 2012 lol. Where are you getting the welding done? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 7, 2012 Author Moderators Share Posted April 7, 2012 Someplace in mannassas--highflow customs or something...? Talked to the owner and he seems like he knows what's goin on, gonna try to stop by next week during the day. The place near Baltimore is just a bit too far away. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
philly15 Posted April 8, 2012 Share Posted April 8, 2012 i had an lc-1 on my wrx worked very well my friend had an issue tuning with some AEM UEGO's not sure what specifically Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 9, 2012 Author Moderators Share Posted April 9, 2012 i had an lc-1 on my wrx worked very well my friend had an issue tuning with some AEM UEGO's not sure what specifically Well, will have to see since it's what i got now I have ZERO idea on how I'm going to install this thing though...ugh. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
bmx045 Posted April 9, 2012 Share Posted April 9, 2012 the aem is great, i hear lc-1's have calibration woes? constant recal? Link to comment Share on other sites More sharing options...
philly15 Posted April 9, 2012 Share Posted April 9, 2012 ^never had that issue maybe there was a bad batch or something that seems to happen every now and then Link to comment Share on other sites More sharing options...
bmx045 Posted April 9, 2012 Share Posted April 9, 2012 someone said it needs to be recalibrated or something, and isnt as on-the-fly as the aem's. every start up the aem recals itself without needing to do anything Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 9, 2012 Author Moderators Share Posted April 9, 2012 In researching the different setups I think the innovate ones recommended an "open air" calibration every 3000 miles or so. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
robitrice Posted April 9, 2012 Share Posted April 9, 2012 LC1's suck to calibrate if you dont wire in the calibration LED. It flashes different ways to ensure you are calibrating correctly and that it is complete. Recalibrating isnt that tough though and takes 3 minutes. Ive done well over 3000K miles on mine and it reads spot on every start up. Link to comment Share on other sites More sharing options...
mmmmspecb Posted April 10, 2012 Share Posted April 10, 2012 The PLX system has been great so far. Definitely a quality unit. I am using it in conjunction with the vbg1 gauge and it connects using a direct digital signal. I can also run the cable to my laptop to datalog with romraider. Link to comment Share on other sites More sharing options...
sjwelna Posted April 16, 2012 Share Posted April 16, 2012 I'm going to buy the Zeitronix zt-2 setup with the black box logger (ability to log to SD card w/o laptop) when I finally buy one. I would have gone with the LM-2 but after reading a bit of mixed reviews on it I looked around some more. I was looking to be able to use it for my motorcycles as well so I didn't want to NEED a laptop to log. It seems to be well thought of AND it is compatible with RomRaider directly, so it fits everything I want for ~$400. -Steve Link to comment Share on other sites More sharing options...
ChefRacer Posted April 17, 2012 Share Posted April 17, 2012 I love my plx setup, it was easy to setup and install and I have no problems with it whatsoever. Plus it was quite affordable especially for the amount of technology it has. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 17, 2012 Share Posted April 17, 2012 the aem is great, Link to comment Share on other sites More sharing options...
