westy66 Posted September 27, 2011 Share Posted September 27, 2011 i woke up to a SATURATED passenger side floor this past weekend i checked and theres no junk up in the sunroof track and im assuming either the drain is clogged at the bottom or the tube popped off. either way i need to find where they go. i park under trees in my yard and thats probably what caused it. can someone point me in the direction of the drain hose(s). i did a search and came up empty. i have the 'vacation pictures' but i cant seem to find the page. thanks in advance Bob Link to comment Share on other sites More sharing options...
hassa Posted September 29, 2011 Share Posted September 29, 2011 In for suggestions......I got out of work today and when putting the little man in his car seat, I noticed the passenger side carpet was soaked! Worse in the front foot well but has spread under seat to rear foot well carpet. My guess was either the clogged drain for sunroof or maybe a clogged/loose AC condensation drain???? ***Edit......I knew I recently came across a similar thread and so kept searching and finally found it......here you go: http://legacygt.com/forums/showthread.php/water-passenger-footwell-18050.html Link to comment Share on other sites More sharing options...
westy66 Posted September 29, 2011 Author Share Posted September 29, 2011 thanks. lots of good reading there..... and frustration!! Link to comment Share on other sites More sharing options...
.blackgt. Posted September 29, 2011 Share Posted September 29, 2011 It's the ac drain hose and was most likely caused by you parking under a tree. Blow an air gun through the bottom of it. Problem solved. Link to comment Share on other sites More sharing options...
