SpeedNeeder Posted June 13, 2011 Share Posted June 13, 2011 I am getting a P0302 on my car. I used some fuel injector cleaner and it helped for a little while, but doesn't seem to be helping any more. I want to swap my #2 injector with another. I have been searching for a how to on this but I haven't found on yet. Can someone point in the right direction? Thanks My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
SpeedNeeder Posted June 13, 2011 Author Share Posted June 13, 2011 Wow, the manual says I have to drain the fuel tank??? My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
BAC5.2 Posted June 13, 2011 Share Posted June 13, 2011 Take the car to someone who knows what they are doing, or find someone who knows what they are doing to help you. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
SpeedNeeder Posted June 13, 2011 Author Share Posted June 13, 2011 That would help! The directions in the manual don't sound too hard, though I have never messed with a fuel system before and I don't have new o-rings on hand as recommended My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
1stick3pedals Posted June 13, 2011 Share Posted June 13, 2011 I'm not sure if there is much difference between the 05s and 09s. But for when I put new injectors in I did the following to relieve the pressure in the fuel system: Unplug the fuel pump fuse. Take your gas cap off. Turn your car on and let it run until it stops. Then turn the key a couple more times and you should be good to go. You'll still have minimal amounts of fuel to deal with when you remove the injectors so have something on hand to soak up the fuel. Link to comment Share on other sites More sharing options...
SpeedNeeder Posted June 13, 2011 Author Share Posted June 13, 2011 Thank you for the info! So do these suckers just pull straight out after you remove the torx screw? My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
1stick3pedals Posted June 13, 2011 Share Posted June 13, 2011 Thank you for the info! So do these suckers just pull straight out after you remove the torx screw? I'm not sure, I don't think mine had a torx screw, I don't honestly remember the exact process. It was really straight forward though, no manual required. Again ours might be different because you have an 05. Mine came out very easily though from what I do remember, it didn't take much effort. Link to comment Share on other sites More sharing options...
SpeedNeeder Posted June 14, 2011 Author Share Posted June 14, 2011 Injectors swapped. Test run complete. No visible leaks or gas smell. Those things were a pain to get back in though. Tried to lube the O rings with gas, that didn't work, so I used old fashioned spit? Wish me luck! My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
SpeedNeeder Posted June 16, 2011 Author Share Posted June 16, 2011 Two days with plenty of stop and go and no CEL. I 'think' it idles smoother too. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
sanderjesse7 Posted February 19, 2012 Share Posted February 19, 2012 hows it running now? i just got the cel too:( Link to comment Share on other sites More sharing options...
SpeedNeeder Posted February 19, 2012 Author Share Posted February 19, 2012 Funny you should ask - I got a P0304 just last week Looks like I need to replace it. Not sure if I can replace just one or if I need to get four of them. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
Pyrojones Posted November 12, 2012 Share Posted November 12, 2012 I need to do this... just replaced my sparks and still have a rough idle with a CEL Cyl 3 Misfire. This seems to be the only current thread that is short and still on topic! Link to comment Share on other sites More sharing options...
ibr_adam09 Posted November 12, 2012 Share Posted November 12, 2012 http://legacygt.com/forums/showthread.php/injector-install-replacement-pics-189140.html Link to comment Share on other sites More sharing options...
LGT612 Posted November 12, 2012 Share Posted November 12, 2012 I would not use spit to lube an injector O-ring. May cause corrosion in the bore. Fuel is always your best bet here. Sounds like you may have isolated your problem; have you tried an Injector Balance Test? As far as injectors, you can certainly replace just one but I always recommend replacing them all at once. Diesel also works as a lubricant for O-rings. Just not too much, it is much slicker than gasoline Link to comment Share on other sites More sharing options...
Max Capacity Posted November 12, 2012 Share Posted November 12, 2012 dish soap or vaseline works well too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hoopaju Posted February 14, 2015 Share Posted February 14, 2015 Petroleum jelly Link to comment Share on other sites More sharing options...
benena Posted April 14, 2015 Share Posted April 14, 2015 dish soap or vaseline works well too. I'm not sure if this is a joke, can I really? I was thinking about using some engine oil? Link to comment Share on other sites More sharing options...
KRM Posted April 14, 2015 Share Posted April 14, 2015 I use dielectric grease on o rings Link to comment Share on other sites More sharing options...
