krot84 Posted December 27, 2014 Share Posted December 27, 2014 Hey I kinda look stupid right now, but today, after driving the car for two years i've noticed that i have heated mirrors (i saw the connector at the back of the mirror glass). the thing is, i never noticed if the heating wors. How do i turn the heating on ? Is there a dedicated bottom for this? Link to comment Share on other sites More sharing options...
bluesuby Posted December 27, 2014 Share Posted December 27, 2014 There's a push button on the extreme left side of the dash. If I'm not mistaken the heater element in the windshield glass is also activated when you heat up the mirrors. Owner's manual? Link to comment Share on other sites More sharing options...
krot84 Posted December 27, 2014 Author Share Posted December 27, 2014 I don't have the windshield deicer, therefore the is no such button. I've attached the photo of the console buttons Link to comment Share on other sites More sharing options...
I3eXa Posted December 27, 2014 Share Posted December 27, 2014 Looks like your car didn't come with that option but has the wire harness for it. Link to comment Share on other sites More sharing options...
krot84 Posted December 27, 2014 Author Share Posted December 27, 2014 So how should the mirror heater be turned on?? Link to comment Share on other sites More sharing options...
I3eXa Posted December 27, 2014 Share Posted December 27, 2014 So how should the mirror heater be turned on?? well you would need to buy the dash switch, and heated mirrors for it to work if I'm not mistaken. Also would wanna replace the windshield to take advantage of the heated wiper area. Not 100% sure but car manufactures will typically use the same wiring harnesses for different trim levels but obviously not have some plugs hooked up since your car trim level didn't come with it from the factory. Link to comment Share on other sites More sharing options...
lee07 Posted December 27, 2014 Share Posted December 27, 2014 It comes on when you turn on your defrost. Link to comment Share on other sites More sharing options...
krot84 Posted December 27, 2014 Author Share Posted December 27, 2014 So guys, which one is it?? Sent from my Nexus 7 using Tapatalk Link to comment Share on other sites More sharing options...
BoyceWare Posted December 27, 2014 Share Posted December 27, 2014 I believe the heating element activates upon reaching 88mph. Has something to do with the flux capacitor. Source: http://en.m.wikipedia.org/wiki/DeLorean_time_machine Link to comment Share on other sites More sharing options...
DavidInSeattle Posted December 27, 2014 Share Posted December 27, 2014 Look at your mirror. It has the same symbol as your rear defrost. Ergo... Link to comment Share on other sites More sharing options...
I3eXa Posted December 27, 2014 Share Posted December 27, 2014 If you don't have the button on the dash I highly doubt you have the heated mirrors installed Link to comment Share on other sites More sharing options...
FLlegacy Posted December 27, 2014 Share Posted December 27, 2014 They work with the defrost, same way with my wifes 07 tribeca and my 10 lgt. If the mirrors are factory installed they will work. No manufacturer is going to spend money installing heated mirrors that don't work. Link to comment Share on other sites More sharing options...
krot84 Posted December 27, 2014 Author Share Posted December 27, 2014 Yes they're factory installed, i doubt that the person before me installed them with the whole wiring if they don't work. you mean the rear window defrost button ? Link to comment Share on other sites More sharing options...
cbeierl Posted December 27, 2014 Share Posted December 27, 2014 At least with my 2009 Legacy 2.5i Limited the outside mirror defoggers operate along with the rear window defogger. I do have a button on my dash, but that's for the windshield wiper defroster. Link to comment Share on other sites More sharing options...
FLlegacy Posted December 27, 2014 Share Posted December 27, 2014 I mean with he windshield defrost button. That's how mine work on both cars. Link to comment Share on other sites More sharing options...
boxman Posted December 27, 2014 Share Posted December 27, 2014 Mine work with the rear defrost button. The front windsheild defrost button does not activate the mirror heaters, just the heating element under the front wipers. Link to comment Share on other sites More sharing options...
I3eXa Posted December 27, 2014 Share Posted December 27, 2014 Mine work with the rear defrost button. The front windsheild defrost button does not activate the mirror heaters, just the heating element under the front wipers. The front defrost button under the radio put the air into the windshield from the top of the dashboard. The rear defrost button under the radio works the rear glass heating element and outside door mirrors. The dash push button on the left of the steering wheel by the mirror adjustment turns on the heating elements on the front windshield Link to comment Share on other sites More sharing options...
boxman Posted December 28, 2014 Share Posted December 28, 2014 Mine work exactly as I described and have since I bought it in '05 on more frosty days than I care to count. Link to comment Share on other sites More sharing options...
FLlegacy Posted December 28, 2014 Share Posted December 28, 2014 No that's not how it works. The front defrost button under the radio put the air into the windshield from the top of the dashboard. The rear defrost button under the radio works only the rear glass heating element. The dash push button on the left of the steering wheel by the mirror adjustment turns on the heating elements on the front windshield and outside door side mirrors Actually that is exactly how they work. http://techinfo.subaru.com/proxy/69502/pdf/ownerManual/069502_2007_Legacy/MSA5M0704A_10.pdf Page 3-50 in the owners manual says so. Mirror heaters are activated with the rear defroster /end Link to comment Share on other sites More sharing options...
I3eXa Posted December 28, 2014 Share Posted December 28, 2014 Actually that is exactly how they work. http://techinfo.subaru.com/proxy/69502/pdf/ownerManual/069502_2007_Legacy/MSA5M0704A_10.pdf Page 3-50 in the owners manual says so. Mirror heaters are activated with the rear defroster /end Yep my bad. Not thinking straight Link to comment Share on other sites More sharing options...
boxman Posted December 28, 2014 Share Posted December 28, 2014 No that's not how it works. The front defrost button under the radio put the air into the windshield from the top of the dashboard. The rear defrost button under the radio works the rear glass heating element and outside door mirrors. The dash push button on the left of the steering wheel by the mirror adjustment turns on the heating elements on the front windshield Edit fail: Tells me that's not how it works, posts detailed incorrect instructions, get's pointed to owners manual describing exactly what I'd described, edits post to describe what I did but leaves the "No that's not how it works." Link to comment Share on other sites More sharing options...
I3eXa Posted December 28, 2014 Share Posted December 28, 2014 Better? Link to comment Share on other sites More sharing options...
