oyway Posted May 16, 2010 Share Posted May 16, 2010 Hello! I have a turbocharged Legacy, first generation (1992). It's the european spec with 2 liter turbo engine (EJ20). Because I'm living in Israel and it's a very hot country, I want to change my intercooler to a bigger\better one (thought about Impreza's one...). Will it fit to my Legacy? what will I have to replace except of the intercooler? This is a picture of my engine (while I'm checking the oil level... :-) ) http://lh5.ggpht.com/_2EtnCJfXc60/S-2XBgtBWnI/AAAAAAAADpw/xSLsmgSNT9U/IMG_0369.jpg I know that my engine is dirty... Thank you very much! Daniel. Link to comment Share on other sites More sharing options...
wtdash Posted May 18, 2010 Share Posted May 18, 2010 Hi, Since you have an AWIC (Air-to-Water-Intercooler) you may already have the best setup. A regular intercooler will probably get 'heat-soaked', unless you do a lot of high speed driving. One thing you can do is get a larger heat exchanger for the water going thru the intercooler. Good luck, Td Link to comment Share on other sites More sharing options...
Bdubs Posted May 19, 2010 Share Posted May 19, 2010 Hi, Since you have an AWIC (Air-to-Water-Intercooler) you may already have the best setup. A regular intercooler will probably get 'heat-soaked', unless you do a lot of high speed driving. One thing you can do is get a larger heat exchanger for the water going thru the intercooler. Good luck, Td I agree. Just staying with the AWIC is more than likely your best option for you. Many of us here in the states have upgraded to this (was never offered here) over a traditional intercooler setup. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted May 22, 2010 Share Posted May 22, 2010 Stack 10 cubes of dry ice on the intercooler. It will cost you several hundred dollars, but you'll get better performance for at least 10 mintes. JKLOL.................................................... Link to comment Share on other sites More sharing options...
