blongo804 Posted April 9, 2013 Share Posted April 9, 2013 Hey everyone! All I have is one quick question.. 17x8.25 +35 offset wheel fitmnet with 235/40 tires. I'm lowered about 1.5" all around - will I rub? Link to comment Share on other sites More sharing options...
careercadaver Posted April 9, 2013 Share Posted April 9, 2013 http://legacygt.com/forums/showthread.php?t=4426 It doesn't look like it...not from this thread at least. In order to get into the +30's you'd need to go 9.5". With a pull and roll...even with 9" you'd need to roll your fenders...tire size comes into play as well... Link to comment Share on other sites More sharing options...
Drift Motion Posted April 9, 2013 Share Posted April 9, 2013 doubt it unless you want to run 245/255s and why do you need 9.5" wide wheels to go ET in the 30 range?! Link to comment Share on other sites More sharing options...
blongo804 Posted April 9, 2013 Author Share Posted April 9, 2013 I kinda wanted to run 245's but if they'll rub and 235's won't, then sounds fine to me. Now to pull the trigger on these wheells... hmm... Link to comment Share on other sites More sharing options...
charlie_sheen Posted April 9, 2013 Share Posted April 9, 2013 if you have more than 2 inch tire gap i wouldnt say you will rub. maybe during hard corners under braking/accelerating. but not over bumps. Link to comment Share on other sites More sharing options...
blongo804 Posted April 9, 2013 Author Share Posted April 9, 2013 My gap may be about two fingers but I consider my hands girly hands .. I'm 6'1" with not the manliest hands lol. Yes I admit!! Link to comment Share on other sites More sharing options...
careercadaver Posted April 9, 2013 Share Posted April 9, 2013 why do you need 9.5" wide wheels to go ET in the 30 range?! Just referencing the stickie I posted a link to. It shows fitment for a 9" wide wheel in the mid to high et40's and as low as et38 in a 9.5"...I know I've seen lower on some cars in the LOW Legacy thread though some fitment comes down to spoke design... Link to comment Share on other sites More sharing options...
Drift Motion Posted April 9, 2013 Share Posted April 9, 2013 Just referencing the stickie I posted a link to. It shows fitment for a 9" wide wheel in the mid to high et40's and as low as et38 in a 9.5"...I know I've seen lower on some cars in the LOW Legacy thread though some fitment comes down to spoke design... please do more research.... brake clearance is related to spoke design wheel fitment does not have anything to do with spoke design, width and ET stays the same regardless of spoke design I kinda wanted to run 245's but if they'll rub and 235's won't, then sounds fine to me. Now to pull the trigger on these wheells... hmm... Roll the fender lips FLAT, you can run 245s, have enough suspension travel paired with coilovers, you can easily run 255s Link to comment Share on other sites More sharing options...
blongo804 Posted May 4, 2013 Author Share Posted May 4, 2013 Edited my question to a new wheel/tire size to get some clarification. Wheels are being installed tomorrow with fingers crossed. Link to comment Share on other sites More sharing options...
