chimaira4deth Posted January 23, 2016 Share Posted January 23, 2016 So when I switch my climate controls from vent to defrost and or Feet, it never switches from the front vents. It constantly dumps air out of the front vents, Almost as if the motor or something has stopped moving. Is there a trick to getting this up and going. I've read the dash is a pain to take apart and remove. Or do I not have to? Any one else had this problem? Link to comment Share on other sites More sharing options...
solidxsnake Posted January 23, 2016 Share Posted January 23, 2016 Do you mean all four front vents (two far side ones, two center)? Only the center two are switchable from the climate controls, to disable the side ones you need to use the lever. Taking the dash apart isn't THAT hard... it's just time consuming and a little tedious. Technicality-wise, it's pretty simple. Search for "vacation pix" and you'll have some guidance. Link to comment Share on other sites More sharing options...
chimaira4deth Posted January 23, 2016 Author Share Posted January 23, 2016 All four front vents. Can't defrost my windshield. Will not switch Is the lever accessible without taking it apart?. I'm in a snow storm at the moment. Link to comment Share on other sites More sharing options...
apexi Posted January 24, 2016 Share Posted January 24, 2016 Sound like it could be the mode door actuator? It looks like you should be able to check it from inside the glove box area, towards the top left somewhere. Might have to remove the glove box, but that's not too bad. Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 24, 2016 Share Posted January 24, 2016 You might remove the entire front face unit of the stereo/climate control unit and clean the contacts that plug into the face and see if that helps. They sometimes become a bit corroded and I've found this to help on a friend's car. Link to comment Share on other sites More sharing options...
apexi Posted January 25, 2016 Share Posted January 25, 2016 Kinda cool, in this video I think you can see the mode door actuator in action. Maybe check out yours and see if it's moving. From post #46 in this thread. Link to comment Share on other sites More sharing options...
chimaira4deth Posted January 25, 2016 Author Share Posted January 25, 2016 Right on, thanks for the replys. Gonna give it My best shot and conclude this thread in original post when fixed Link to comment Share on other sites More sharing options...
zanzabar Posted May 16, 2016 Share Posted May 16, 2016 did yours just stop working or did it make a kind of grinding motor slip sound. Link to comment Share on other sites More sharing options...
Wagonation Posted May 17, 2016 Share Posted May 17, 2016 Mode actuater fail. If toggling between modes doesnt help then you are prob hosed and need new. Link to comment Share on other sites More sharing options...
