x__CRASH__x Posted February 2, 2015 Share Posted February 2, 2015 My car is from Florida, but here in CA we are required to have a front license plate. I had hoped to avoid putting one on, as the previous owner did for a few years. But my wife got pulled over for a fit-it ticket yesterday. So I have to do something about it. I don't like them, so what options do I have for placement? There is a bracket that puts the plate over one side of the lower intake, but will that restrict intake flow? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 2, 2015 Share Posted February 2, 2015 Yes, I think Grimmspeed makes one that mounts to the tow hook point. See that little panel below the right headlight ? It mounts in there. I also made a hinged plate hanger for the turboed Civic big FMIC. I took a flat piece of Al mounted a hinge ot it hung the plate off the hinge and used sheet metal screws to mount the Al panel up under the bumper cover below the bumper support that is covered by the big poly bumper cover. Funny you mention CA, yesterday driving back from VT I passed a Bently with CA plates. When I got in front of him I noticed he didn't have a front plate. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
subiebeast22 Posted February 2, 2015 Share Posted February 2, 2015 I just moved from CT to FL im so happy I don't need a front license plate! I agree I hate how it looks on our cars Link to comment Share on other sites More sharing options...
Redslaya Posted February 2, 2015 Share Posted February 2, 2015 you can build a relocate kit for only a few bucks using the OEM tow hook. looks good, is legal, and doesnt cost of much as the grimspeed here are the pictures of my building mine Link to comment Share on other sites More sharing options...
Drift Motion Posted February 3, 2015 Share Posted February 3, 2015 technically tow hook is not legal law says the plate has to be attached to the bumper with screws or something along the lines of that...and the tow hook isn't really attached to the bumper Link to comment Share on other sites More sharing options...
Scotty Posted February 3, 2015 Share Posted February 3, 2015 technically tow hook is not legal law says the plate has to be attached to the bumper with screws or something along the lines of that...and the tow hook isn't really attached to the bumper Can you cite the law? It just needs to be securely fastened at the front of the car with the characters upright and be less than 60" from the ground. Link to comment Share on other sites More sharing options...
turboboost Posted February 4, 2015 Share Posted February 4, 2015 As others have mentioned, a popular option is the Grimmspeed license plate relocation kit. It's a bit pricey for what it is, but works well. There's a few cheap ebay options that are just metal brackets that you screw into either sides of your lower grill, then mount the license plate. You can also go the Rattsl way, which is just placing your license plate into your lower grill, resting it against your rad -- supposedly, the air pressure keeps it in there without issue (although, I personally wouldn't go this route). Link to comment Share on other sites More sharing options...
alex0856 Posted February 4, 2015 Share Posted February 4, 2015 Here's Washington's front license plate law, quoted directly from RCW 46.16A.200: (5)(a) Display. License plates must be: (i) Attached conspicuously at the front and rear of each vehicle if two license plates have been issued; (ii) Attached to the rear of the vehicle if one license plate has been issued; (iii) Kept clean and be able to be plainly seen and read at all times; and (iv) Attached in a horizontal position at a distance of not more than four feet from the ground. (b) The Washington state patrol may grant exceptions to this subsection if the body construction of the vehicle makes compliance with this section impossible. In Washington, there's no specifics on HOW you mount the plate, just that it's on the front and conspicuous. I would imagine most states have their laws set up similarly. Then again, it's California. They might have requirements for license plate aerodynamics . I built a home-made relocation kit for my Honda. Got pulled over 2 or 3 times with it and never got any trouble. It's located in the lower grille in the bumper cover. No room for this on an LGT but on my Honda the opening is almost the perfect height. I run a GrimmSpeed kit on my LGT. I was able to pick mine up used for $60, but after doing lots of reading on home-made kits and trying to come up with my own ideas, I gave up and opted for the GrimmSpeed kit and would have bought a new one had I not found the used one. Two reasons for this: 1: VERY adjustable, you have a wide range of options for vertical and horizontal adjustment. This allowed me to get it placed so that it does not block my fog light beam. 2: If I ever need to tow my car (It's an LGT, it'll happen eventually) I'll need a tow hook, which means I would need to buy a second one if I converted my original into a license plate bracket. It's expensive yes but IMO worth it. Link to comment Share on other sites More sharing options...
x__CRASH__x Posted March 3, 2015 Author Share Posted March 3, 2015 What's the difference in Grimm Speed kits? I mean, I see a WRX kit and it looks the same as the kit for my year specific Legacy which looks the same as the later year kits. Are they all the same thing? Link to comment Share on other sites More sharing options...
alex0856 Posted March 3, 2015 Share Posted March 3, 2015 Yeah, to my understanding. The previous owner of mine had his on an 11 WRX. Link to comment Share on other sites More sharing options...
06leg315 Posted March 3, 2015 Share Posted March 3, 2015 I bought a plate relocation kit for 12 bucks off Ijdmtoy. Works great Link to comment Share on other sites More sharing options...
x__CRASH__x Posted March 3, 2015 Author Share Posted March 3, 2015 Do you have a picture of that? And is that a member of a company? Link to comment Share on other sites More sharing options...
x__CRASH__x Posted March 3, 2015 Author Share Posted March 3, 2015 I guess my question is more: Is the tow hook receptacle the same width/thread? I can't see a difference between kits. I don't want to spend so much when there is a used option, but I want it to work. Link to comment Share on other sites More sharing options...
06leg315 Posted March 4, 2015 Share Posted March 4, 2015 Go on amazon and type in front plate relocate and you will see one from ijdmtoy its like 12 bucks or something. I put it in the lower left it mounted to the bumper on underside in her center cut out. You don't see it Link to comment Share on other sites More sharing options...
x__CRASH__x Posted March 4, 2015 Author Share Posted March 4, 2015 ah, yes, I've seen those. Thanks, but I'm trying to avoid drilling into the bumper. Link to comment Share on other sites More sharing options...
x__CRASH__x Posted March 5, 2015 Author Share Posted March 5, 2015 I found out the difference is the length of the bolt coming out of the tow bar receptacle. Anyone know the size/thread of that bolt? I might pursue the economical route. Link to comment Share on other sites More sharing options...
alex0856 Posted March 5, 2015 Share Posted March 5, 2015 Take your tow hook to a hardware store and match it up. Link to comment Share on other sites More sharing options...
x__CRASH__x Posted March 6, 2015 Author Share Posted March 6, 2015 I don't have a tow hook. I have a threaded hole. Is there a tow hook somewhere in the car I should have? Link to comment Share on other sites More sharing options...
alex0856 Posted March 6, 2015 Share Posted March 6, 2015 Yep, in the trunk with the spare tire. Not sure how it's set up in sedans if you have a sedan, but in wagons you pull up the trunk board and there's a tray that holds the jack, tire iron, tow hook, etc. Mine sits on top of the spare. Link to comment Share on other sites More sharing options...
x__CRASH__x Posted March 6, 2015 Author Share Posted March 6, 2015 Well there we go! Maybe I'll follow the one guy's lead and build something that connects to that tow hook. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted March 6, 2015 Share Posted March 6, 2015 OP, that's weird your wife got a front plate ticket? I haven't been using a front plate for over a year now, never been stopped once. In my experience all the cops stopped caring about the front plate once they took down all the red light cameras. That was really the primary purpose for the strict front plate enforcement in the first place. I drive by cops all the time now with no front plate and they don't seem to do a thing. Link to comment Share on other sites More sharing options...
Scotty Posted March 6, 2015 Share Posted March 6, 2015 Cops typically won't issue just a no plate ticket, usually it is combined with other tickets. For instance, if a cop pulls over a Corvette for speeding, the first thing they do is walk up to the front to check for a plate. Some Corvette owners think they have an exemption, but they don't. Meter Maids will give you a ticket for no plate also. Link to comment Share on other sites More sharing options...
