Sgt.Gator Posted July 8, 2016 Share Posted July 8, 2016 I'm considering an AWIC with a vertical clock outlet on the turbo like the attached pic. I've never done any turbo clocking so I'm unsure of the process and long term consequences. Are there turbos that can or cannot be clocked like this? I'm specifically interested in clocking a Blouch 1.5 Dom XTR or ATP GTX3071. I'll either use a EWG on the uppipe and lock off the IWG, or use the ATP GTX3071R with the built in EWG. Are there any long term consequences to the bearing oiling or water cooling to consider to a vertical clock? Is this a difficult procedure? Thanks for your advice! Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
GTEASER Posted July 8, 2016 Share Posted July 8, 2016 [ame=http://www.youtube.com/watch?v=6gy0wBPW47k]How to Clock a Turbo - by TurboKits.com - YouTube[/ame] GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
gtonstilts Posted July 9, 2016 Share Posted July 9, 2016 As long as the oil drain is straight downwards you can clock it however you need for the application. In addition you can even get around that if you use a pum to assist the drain, but if the pum fails you will burn oil like crazy ! Link to comment Share on other sites More sharing options...
Sgt.Gator Posted July 9, 2016 Author Share Posted July 9, 2016 The video is perfect, thanks! Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
Carlton603 Posted July 13, 2016 Share Posted July 13, 2016 Pretty cool stuff, this is the first I have ever seen/read about clocking a turbo and also awic. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 16, 2016 Share Posted July 16, 2016 Sorry to be late to the game, yea its pretty easy to do. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
