Philski Posted October 17, 2007 Share Posted October 17, 2007 Does anyone know if we can install these in our US Legacy's? http://www.japanparts.com/images/ImageFromDB.php?base=1&no=1795 Are the connectors already factor installed or do they need to be fabricated? I really miss having footwell lights. The puddle ones are nice but...... From Japanparts.com Item No.: 107-115-115 TIA Link to comment Share on other sites More sharing options...
sportwagon Posted September 15, 2009 Share Posted September 15, 2009 I just got these in the mail today.... fron only! Link to comment Share on other sites More sharing options...
jxjjang Posted September 16, 2009 Share Posted September 16, 2009 i'm running the red LEDs for the 08-09 imprezas.. but i had to tap power since we don't have a connection for them. i'm mounting them with double-sided 3M tape too since the mounting points are different than the imprezas Link to comment Share on other sites More sharing options...
sportwagon Posted September 16, 2009 Share Posted September 16, 2009 cool! There are two red power wires running from the harness... I'm assuming one of them is for the illumination, right? Also, they are on all the time, or just when the door is open? Sorry, I'm able to get all of the info I need from the japanese subaru instructions! There are plenty of diagrams and pictures to work with, but I'm not sure about the wiring... Not sure if I need to find a wire to tap that is switched on only when the door is open? Link to comment Share on other sites More sharing options...
Istvan_Sz Posted July 27, 2012 Share Posted July 27, 2012 i'm running the red LEDs for the 08-09 imprezas.. but i had to tap power since we don't have a connection for them. i'm mounting them with double-sided 3M tape too since the mounting points are different than the imprezas How do you run on red LEDs, there is only blue ones anvalible. Or did you replace the blue ones with red? Link to comment Share on other sites More sharing options...
AkumaMax Posted July 27, 2012 Share Posted July 27, 2012 It shouldn't be too hard to install. Brackets will most likly be a pita but as for power just get an "add a fuse" and you will be all set. Link to comment Share on other sites More sharing options...
iNVAR Posted July 29, 2012 Share Posted July 29, 2012 just buy a flat strip of red LEDs and wire it up yourself. for power, tap into a line that's only hot with the headlights. Link to comment Share on other sites More sharing options...
Istvan_Sz Posted August 1, 2012 Share Posted August 1, 2012 The thing is, I want to install the LED strips so if I open the passanger sida door the passenger light will turn on, when I close the door, the lights go out. Likewise with the drivers side. Anyone know if there is fuse that is hot only when the door lamp is on? Or do I have to snatch electricity from the lamps cables? Link to comment Share on other sites More sharing options...
dupontrob24 Posted August 1, 2012 Share Posted August 1, 2012 Why can't you connect them to 12v and then for the ground connect each light to the door pin that triggers the dome light when you open each door. I believe most door pins are a just a ground connection. That way each individual light will be grounded only when that door is opened and it will lose the ground when you close the door. just my thoughts..... Link to comment Share on other sites More sharing options...
cjmx06 Posted August 6, 2012 Share Posted August 6, 2012 I'd def be interested in hearing a way of wiring them with the dome light, so all floor lights come on with the dome regardless of which door is opened. Also that they come on when the interior lights r switched on manually. Link to comment Share on other sites More sharing options...
