glickster89 Posted March 20, 2014 Share Posted March 20, 2014 Whats up guys. New guy here. Just picked up an 05 Legacy Wagon. Like many other I'm sure, the 1st thing I noticed on the car was no aux input. Pretty bummed. After doing some research on Jazzy mods and other things other have done, Im thinking the easiest mod would be to swap an 07 headunit/whole display with the aux input. The car has the analog temp controls just like this. So my question is: will this just swap 100% without any issues? Is the aux in the back of the unit? If so, will all I need is a 3.5mm male-male aux cord? Here is the unit. Thanks for the help guys. http://www.ebay.com/itm/SUBARU-LEGACY-2007-2008-2009-FACTORY-STEREO-6-DISC-CHANGER-MP3-CD-PLAYER-RADIO-/310889167892?pt=Car_Audio_In_Dash_Receivers&hash=item4862703c14&vxp=mtr Link to comment Share on other sites More sharing options...
mikeyvt Posted March 28, 2014 Share Posted March 28, 2014 Not sure if you received your answer but as far as the swap goes I know on my swap with the auto controls it was a pretty straight foward swap. The aux input is actually in the center console of those years and it's connected to the radio by a connector. The only other option you have besides the jazzy mod is to pick up a module that ill connect to the sat Function of the radio. I picked up a isimple to connect because its plug and play option for 07-09 radios and you can add bluetooth or an aux to it. Grom also makes a plug and play module. Hope that helps. Link to comment Share on other sites More sharing options...
JJr Posted March 28, 2014 Share Posted March 28, 2014 I just did the upgrade using Grom Bluetooth and a OEM Subwoofer, it made a huge sound improvement on top of the Bluetooth ease of use factor. GL Link to comment Share on other sites More sharing options...
