chris07gt Posted December 28, 2011 Share Posted December 28, 2011 Well today I took the turbo out of my 07 gt.....expecting to take a vf40 out, mind you I've already bought another vf40 off a 08 wrx thats getting swapped in. Now What I pulled out was not a vf40, it was a vf46. Any Ideas on to how this thing hasnt blown the car up yet being I drove it on stock map for about say 7 months and the last 3 on cobb stage 2 map. The car always seemed to run harder than most others but I could never figure out why.....until now. Link to comment Share on other sites More sharing options...
DocHolladay23 Posted December 28, 2011 Share Posted December 28, 2011 VF46 comes stock on 07-09 LGTs [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted December 28, 2011 I Donated Share Posted December 28, 2011 And the 08 WRX comes with a TD04, not a VF40 or a VF46. Link to comment Share on other sites More sharing options...
Nrw Posted December 28, 2011 Share Posted December 28, 2011 and 08 wrx's have TD04's edit:damnit too slow Link to comment Share on other sites More sharing options...
browningr6 Posted December 28, 2011 Share Posted December 28, 2011 so what is the difference in the tdo4, vf40, and vf46 Link to comment Share on other sites More sharing options...
whitetiger Posted December 28, 2011 Share Posted December 28, 2011 td04 is smaller than the vf40. vf46 is a revised vf40 with 5-arc compressor wheel with slightly better midrange. vf46 is more reliable and is the best of the 3 but not by much. Link to comment Share on other sites More sharing options...
browningr6 Posted December 28, 2011 Share Posted December 28, 2011 Thanks!! Link to comment Share on other sites More sharing options...
contractkiller Posted December 28, 2011 Share Posted December 28, 2011 whomp whomp whomp.... hope you can get a refund Chris. Was the vf40 or TD04 you had intended to install a replacement for a factory turbo that was on its way out the door or were you looking to upgrade? Just a thought, if looking to upgrade, an 09 STi "VF52" is certainly an upgrade or BNR Supercars out of AL has a few different setups that are relatively inexpensive. Two of which, the 16G and 18G, require really no supporting mods but a tune... what did u mean when you said. it felt like i was driving a civic? did u mean the car felt like it was more dependable and it was getting better mpg's? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted December 28, 2011 I Donated Share Posted December 28, 2011 Just a thought, if looking to upgrade, an 09 STi "VF52" is certainly an upgrade or BNR Supercars out of AL has a few different setups that are relatively inexpensive. Two of which, the 16G and 18G, require really no supporting mods but a tune... The VF52 is the 09+ WRX turbo. The 08+ STI uses the VF48. And the 18G should really have fuel mods, and even the 16G needs Stage 2 level mods. Link to comment Share on other sites More sharing options...
contractkiller Posted December 28, 2011 Share Posted December 28, 2011 The VF52 is the 09+ WRX turbo. The 08+ STI uses the VF48. I stand corrected. In any case either would be an upgrade though... And the 18G should really have fuel mods, and even the 16G needs Stage 2 level mods. nah, the 18G does just fine on factory fuel system. Dont expect it to reach its true potential without fuel mods though. what did u mean when you said. it felt like i was driving a civic? did u mean the car felt like it was more dependable and it was getting better mpg's? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted December 29, 2011 I Donated Share Posted December 29, 2011 nah, the 18G does just fine on factory fuel system. Dont expect it to reach its true potential without fuel mods though. Define "does fine." It has more lag than a 16G, and won't make much more power, so you don't get a lot for your extra $50 unless you spend the money on injectors and a fuel pump. I was choosing between them when I got my 16G, and the general consensus was that if I wasn't planning on fuel mods, I was wasting my money. BTW, the VF48 won't work as a plug-and-play upgrade -- it's an 02-07 WRX style turbo, so you need to replace the intake manifold and intercooler too if you want to use it. Link to comment Share on other sites More sharing options...
Nrw Posted December 29, 2011 Share Posted December 29, 2011 Define "does fine." It has more lag than a 16G, and won't make much more power, so you don't get a lot for your extra $50 unless you spend the money on injectors and a fuel pump. I was choosing between them when I got my 16G, and the general consensus was that if I wasn't planning on fuel mods, I was wasting my money. BTW, the VF48 won't work as a plug-and-play upgrade -- it's an 02-07 WRX style turbo, so you need to replace the intake manifold and intercooler too if you want to use it. or just go front mount and keep your manifold Link to comment Share on other sites More sharing options...
chris07gt Posted December 29, 2011 Author Share Posted December 29, 2011 I am just looking to replace for this car as I plan on selling it within the next few months and finding myself a 08 spec b to replace it. hopefully Link to comment Share on other sites More sharing options...
bmx045 Posted December 29, 2011 Share Posted December 29, 2011 then get a vf46...? half of this thread consists of people giving wrong info and being corrected why are you replacing the turbo? is it blown? shaft play? oil leaks? Link to comment Share on other sites More sharing options...
contractkiller Posted December 29, 2011 Share Posted December 29, 2011 Define "does fine." I mean it runs without any codes or weird business. As stated, you wont see its full potential without fuel mods but if hes in the position I was, (blown turbo, short on funds, needs a replacement but doesnt have an extra $1000-1500 to throw down on supporting mods yet.) it will work without upgrading fuel system. what did u mean when you said. it felt like i was driving a civic? did u mean the car felt like it was more dependable and it was getting better mpg's? Link to comment Share on other sites More sharing options...
