AWFUL mileage in new-to-me '95 Leggy LS
nawoj
Oi! recently purchased this car from my sister who let it sit and rot for about 2+ years. I think it ran for maybe 3 mos. during this time. i won't get into the smell....... i dropped in a new battery, turned the key, and soiled myself: the damn 2.2 burst into life with nary a tick! All i've done is replace the fluids, air filter and cleaned up the brakes/lines. And im also currently running it on my '05 lgt's stock wheels (17"). So, why am i getting MAYBE 16 mpg? Should i check/change the plugs? Or are the 17"s the culprit? (they're on the car because the stock 15"s are shot, not to look "fly")what would a dealer charge for a tuneup? Any help would be sweet.
Clean the MAF. Injector cleaner helps. Changing the plugs would probably make a big difference. they are pretty easy to change on the 2.2, unlike the 2.5... Plug wires could help too, I changed mine because one of them actually broke when I was taking it off the plug. I think it cost me $25 for all 4. That should make a big difference. If you still want to go farther, take off your carburetor/intake and clean that out.
Also check that the rolling distance per turn of the 17" is close to that of the 15" so you don't get skewed figures from that.
But otherwise I would say that a thorough check of the injectors is one item, and new plugs and cleaning of the high-voltage parts is another. Check all vacuum tubes to make sure that they haven't been a meal for some rodent.
Also drive a short distance and make sure that no brakes are sticking causing unnecessary drag. This is producing a lot of heat at the wheels, so just check if the brakes/hubs gets warm.
And then you shall check the pins that the brake calipers floats on so the calipers aren't sticking on the pins. That can cause you to get bad brake performance and corrupt your brake discs. Dirty but simple work, mostly annoying if you don't have a garage.
Just make sure that you don't have any inhabitants in the air intake - like mice or rodents that mess things up. A big nest in the air intake will sure cause problems.
And finally - warm the car up, fill it up at the gas station, take a drive and fill again to check what the consumption is when you take a drive with a warmed-up car. The fuel consumption figures will be off the "standard" values when driving in cold weather, especially with a cold car. Use injector cleaner when you fill up, especially since it has been out of use for a long time and some things may need time to loosen up.
Try Seafoam. Run it through the PCV system, Fuel System, and throw some in the crankcase for a couple days before you change the oil.
Also, change the PCV valve while you are at it. I've never used a full can in a tank of fuel, but you may want to consider. Only around 1/4 can in the pcv system, and put the rest in the crank case.
i've never heard anyone advocate for the fuel system cleaners that go through the gas tank - those who recommended it, have you seen positive (or any) results?
Yeah. It can help keep things tidy, it won't clean a horribly dirty engine, but it can't hurt.
awesome. thanks everyone for the advice. i'll pull the plugs and clean the MAF, and maybe try som of that magic snake oil some of you mentioned. i'm confident it's not the brakes, but i will stop halfway home and see if they're hot. i've run a few tanks of shell 93 (vpower!) and now run on whatever's on sale, so old go-sauce isn't it. i'll check back in and hopefully do some back-patting. thanks again!
I'm averaging 16mpg right now myself. I'm blaming it on cold weather idling in the morning (not more than a minute or two), soft rubber on my snow tires, spinning in snow, and constant uphill and downhill driving commuting to work.
  • 7 months later...
i recently picked up a 95 LSi and the last tank measured around 20mpg for all in town driving. the car has been well maintained the last couple of years by the previous owner. however i do plan on changing both diffs to a synthetic and also the trans to Valvoline Maxlife Syn blend trans fluid. looking into a home made grounding kit to help with electrical efficiency. may change the 02 sensor and add a high flow cat later. i would love to see this thing get close to 23-25 in town
Hmmm, my 1997 2.2 gets a consistent 27-29mpg w/ snows.
  • 3 weeks later...
Dude i get shitty gas mileage. Change filter, change plugs/wires, change oli. Still i get 15 around city.
Is it normal to see your gas gauge drop a little when you cold start your car, plus i smell gas every cold start, could be bad cat but i dont know...
