deeslk Posted November 4, 2007 Share Posted November 4, 2007 If someone would be able to measure the ground clearance of their Stock Y-Pipe for me or even non stock ones. I have an SPT v2 CBE and I only have 3.5inches of clearance to the ground. Wondering what others have. I have an 08GT stock suspension. Thanks. Link to comment Share on other sites More sharing options...
eL GaTo Posted November 4, 2007 Share Posted November 4, 2007 If someone would be able to measure the ground clearance of their Stock Y-Pipe for me or even non stock ones. I have an SPT v2 CBE and I only have 3.5inches of clearance to the ground. Wondering what others have. I have an 08GT stock suspension. Thanks. Most of the aftermarket "Y" pipes have same issue. Careful when you "lower" your car. "Remember..."MODDING is a HOBBY:icon_bigg, not a BAAAD HABIT";) . Link to comment Share on other sites More sharing options...
BigBad Posted November 4, 2007 Share Posted November 4, 2007 Couldn't tell you the stock measurement since its been so long since I swapped that out, but my Greddy SP2 exhaust has 4 - 4.25" of clearance from the lowest point of the Y-pipe. My Y is def tighter to my rear sway bar than yours. Link to comment Share on other sites More sharing options...
Seth1784 Posted November 5, 2007 Share Posted November 5, 2007 hks here im lowered about 1.5"s on coils as well and i think i have around 5 or so inches... i'll try to measure at lunch or after work though for you. Link to comment Share on other sites More sharing options...
deeslk Posted November 5, 2007 Author Share Posted November 5, 2007 Thanks... always impressed with this forum. Hmmm maybe 5inches, I definitely have to see what I can do to get my tucked a bit more Link to comment Share on other sites More sharing options...
Seth1784 Posted November 5, 2007 Share Posted November 5, 2007 how low does your car sit there deeslk? you gotta be seriously low or something lol. i'll have to take a peak but i know our y's look different for sure, perhaps each brand did a little different path or something to gain extra clearence? Link to comment Share on other sites More sharing options...
deeslk Posted November 5, 2007 Author Share Posted November 5, 2007 Nope am on stock suspension, it's only 3.5 inches of clearance about an inch and a bit from the rear sway bar so I know I can probably squeeze it up less than an inch so. Just need to see what some other 08 GTs with SPT have. As the car is a couple inches shorter vs 05-07 so maybe the hangers are slightly different. Link to comment Share on other sites More sharing options...
NewLegGT67 Posted November 5, 2007 Share Posted November 5, 2007 Something is definitely not right if you have only 3.5'' of clearance on a stock suspension with the SPT catback. Is the Y pipe exhaust hanger in place? Perhaps someone with the same exhaust will chime in. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
rao Posted November 5, 2007 Share Posted November 5, 2007 Mine is 5.5" with the Lachute y-pipe and stock height suspension. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
deeslk Posted November 5, 2007 Author Share Posted November 5, 2007 Thanks, and yep the hanger is all in place will take a look later tonight again. Link to comment Share on other sites More sharing options...
jerami1981 Posted November 5, 2007 Share Posted November 5, 2007 5" even from the lower edge of the connecting flange which is the lowest point on mine. perrin mid/y-pipe, stock suspension. Link to comment Share on other sites More sharing options...
Boostjunkie Posted November 6, 2007 Share Posted November 6, 2007 Just a bit over 4" of clearance from my Megan Racing CBE's y-pipe to the ground and my car is over 2" lower than stock. On a stock height car there would easily be 6" of clearance. Link to comment Share on other sites More sharing options...
deeslk Posted November 6, 2007 Author Share Posted November 6, 2007 Hey any SPT guys or 08 SPT measurements. Looks like I'm going to have to get under there sort this out. The thing is my tips are tucked nicely not much room for them to move up. Thanks for all the measurements, have to work on this so I can lower it in the spring. Link to comment Share on other sites More sharing options...
mustangendsley Posted November 6, 2007 Share Posted November 6, 2007 I have the SPT set up and Im at 4 inches at the Y pipe to the ground with stock suspinsion. Link to comment Share on other sites More sharing options...
Sephon Posted November 6, 2007 Share Posted November 6, 2007 I had the same question when I had mine installed. I have an '08 with the version 2 SPT. I have about the same amount of clearance. When I get back in town (had to fly back to Atlanta yesterday), I will measure it for sure. -Sephon Link to comment Share on other sites More sharing options...
deeslk Posted November 7, 2007 Author Share Posted November 7, 2007 Ok i was able to get it up to just over 4.5 inches of clearance, without rubbing on anything. I might be able to squeeze a half inch more with some more tweaking. Link to comment Share on other sites More sharing options...
