taylormac1993 Posted August 27, 2014 Share Posted August 27, 2014 Hey guys. Back when I did my 5MT swap I pulled another EJ25D while I was at it. I just got the whole block cracked yesterday and everything is in alright condition. Looks like highway miles with oil changes a little late. Anyway, what I want with this motor is 200+ WHP using the stock block and heads. I also want it to be reliable and to run on 91 octane. I wanted to do E85 but recently some local shops started testing the pump E85 and it turned out to only be E70. I can't risk that variability in the fuel and I'm not gonna test it every time before I fill up. So what I'm wondering is, how doable is this? Are there any threads on making 200 WHP with the stock EJ25D block and heads? Link to comment Share on other sites More sharing options...
Baddog Posted August 27, 2014 Share Posted August 27, 2014 Possible? Maybe. Cost effective? No. I have run a few N/A motor variations here. I have had a 25D with 22E heads with cams, EL header, 2.25 catless, exhaust, grimmspeed manifold spacers, LW flywheel. While it is a fun motor it's not "fast" it's quick and responsive. Maybe 120-140whp depending on climate. Currently I am running a 251 with 25D DOHC heads on stock cams. But with the previous mods listed before as well. Also a fun motor with better mid-range and top end. Probably makes about the same WHP numbers but shifted higher into the power range. Your best bet on 200whp is an EG33 swap with some bolt ons or...a turbo swap. Keep in mine a 2.0L WRX only makes ~170ish whp. Link to comment Share on other sites More sharing options...
taylormac1993 Posted August 28, 2014 Author Share Posted August 28, 2014 Yeah ive been reading all day about it and it seems like the best option is to do a stock rebuild and keep it a daily. No sense in trying to squeeze horse out of a motor that was designed to haul groceries. Link to comment Share on other sites More sharing options...
taylormac1993 Posted August 28, 2014 Author Share Posted August 28, 2014 So what about if I find and ej257? It's an EJ motor, so it will bolt up to my motor mounts and tranny, and I assume the heads will fit? Maybe? Then I just need to complete the turbo setup and I have a ghetto STI swap. Link to comment Share on other sites More sharing options...
Osei Posted September 4, 2014 Share Posted September 4, 2014 If it was that easy, everyone would've done it!!! You forget things like engine management, harness wiring, etc. etc.etc. O. Link to comment Share on other sites More sharing options...
taylormac1993 Posted September 4, 2014 Author Share Posted September 4, 2014 Yeah i guess ill just do a slow stock rebuild as i get money for parts. Then when/if the engine goes ill have a backup motor to throw in and know its good. Link to comment Share on other sites More sharing options...
Baddog Posted September 5, 2014 Share Posted September 5, 2014 I love my N/A frankenmotors. They both have had good power. The EJ25D with the 22 heads had GREAT low end torque and the EJ251/25D head combo has good mid-top end, still with good low end power. I drive my brothers 93 Leggy SS with a 22T and a TD04 @12 psi with a JDM 4.11 transmission and I am never dissapointed when I get back into my car. Is his faster? Yeah no doubt. Link to comment Share on other sites More sharing options...
