KGreb Posted January 4, 2007 Share Posted January 4, 2007 Now that the weather has turned colder and I've had a lot more road tuning time, I'm getting very close to the limits of the stock MAF. I haven't hit 5.0v yet but I'm pretty solidly in the 4.9v range. I can go speed density with my UTEC but would prefer to remain MAF based. The two intakes which I've heard of being used in these cases are the Perrin Big MAF and the APS 70mm. I've heard very mixed results with the Perrin. The APS 70mm seems to be ok but I'm not sure it will fit the LGT. Any suggestions of other intakes I should investigate? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 4, 2007 Share Posted January 4, 2007 Are you running a 20G? Have you read edmundu's review of the AEM CAI? From his numbers, it appeared to be 14% more airflow at the same MAF V. Link to comment Share on other sites More sharing options...
KGreb Posted January 4, 2007 Author Share Posted January 4, 2007 I'm running an LGT 20G. I'll do some searches on the AEM - thanks! Link to comment Share on other sites More sharing options...
edmundu Posted January 4, 2007 Share Posted January 4, 2007 An AEM will unleash some power, if you are still on the stock intake! However, it doesn't lower the MAF all too much. I had previously hit 4.96v-4.98v on the stock MAF, but since going with the AEM it hasn't hit greater than 4.94v, and mostly 4.92v. I don't know about the APS, but AVO's intake is a little bigger, both Wukindada & Sean@Rallitek confirm it. It seems to give about 10-15% more room. So if you have plans on going bigger than 20g, the AVO will be the only choice, well other than Perrin's tough to tune BigMaf. I am actually waiting on an AVO intake now, as when I turn up the wick some more on the Avo450, it will certainly max the AEM out... Link to comment Share on other sites More sharing options...
GTTuner Posted January 5, 2007 Share Posted January 5, 2007 TDC states the K&N flows more.....period! That was his exact quote sometime back here on the forum. PDX did not recomend the K&N and said it was no good, but now I believe they are selling them. Go figuire. Link to comment Share on other sites More sharing options...
firedawgs Posted January 5, 2007 Share Posted January 5, 2007 I am running the K&N because TDC recommended it. Updated my vBGarage: Link to comment Share on other sites More sharing options...
wukindada Posted January 5, 2007 Share Posted January 5, 2007 On a 20g or larger.......AVO;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
