JamiSteven Posted April 21, 2014 Share Posted April 21, 2014 Think I can get away with a new stock clutch on my 05 LGT Wagon? Ive read the countless threads here as well as the reviews but havent found anything that compares pro's/cons of an aftermarket clutch on a mildly modded LGT vs an upgraded stock unit (07+ lgt clutch with wrx SMFW)..Dont really feel like spending upwards of 600 for an aftermarket clutch kit, especially when installation is an arm and a leg as well.. I dont race, highway miles to and from work throughout the week, spirited weekend driving, no launches or anything like that. Mods: Perrin TMIC TurboXS Up Cobb catted down Installing after clutch is replaced: Grimmspeed EBCS VF52 DW65C DW 850cc sidefeeds Link to comment Share on other sites More sharing options...
Max Capacity Posted April 25, 2014 Share Posted April 25, 2014 Sorry, no cheap clutch will hold up in these cars. I hate the OEM clutch, mine would slip when backing up in a few inches of snow. In my 98 GT, 00GT and the 05 GT. I love my Spec clutch's. Had a Spec 2+ and now a Spec 2. read http://legacygt.com/forums/showthread.php/fx350-slipping-15k-223779.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
doobaruGT Posted April 25, 2014 Share Posted April 25, 2014 I really enjoy my comp stage 2. Plenty of bite and a great threshold for power and torque. Just research around and look for something that suits your power output (I would assume you'll be modding more down the road so plan for a greater capability than what is necessary) and then research on here to see what people thought of them. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
schwinn Posted April 27, 2014 Share Posted April 27, 2014 My stage2 06 LGT had issues with the stock clutch pretty early. I installed an ACT clutch, and it was fine until recently when the spring broke (granted, it did have a ton of miles on it). It also has a crazy-heavy pedal. I got used to it, but my wife would always complain about it. My replacement clutch is a CM FX300, and it's VERY nice. Grabs pretty low to the floor, which took a little getting used to, but it's a very light pedal otherwise. I would highly recommend this clutch. Link to comment Share on other sites More sharing options...
JamiSteven Posted April 27, 2014 Author Share Posted April 27, 2014 What mods are you running? HP levels? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
