nightspeed98 Posted August 5, 2010 Share Posted August 5, 2010 i want to create mp3 discs but none have worked yet. anyone know the format? Link to comment Share on other sites More sharing options...
Drift Motion Posted August 5, 2010 Share Posted August 5, 2010 drag the MP3 files into the cd folder burn done Link to comment Share on other sites More sharing options...
blaze741 Posted August 5, 2010 Share Posted August 5, 2010 yeh what he said. for the 09 you should be able to play them no problem. done it before and it has worked fine. Link to comment Share on other sites More sharing options...
Strizzy Posted August 5, 2010 Share Posted August 5, 2010 I use Nero and never had issues. My bad luck build Link to comment Share on other sites More sharing options...
blaze741 Posted August 5, 2010 Share Posted August 5, 2010 mp3 discs even windows can burn. i myself use a free software to do all my burning called infrarecorder Link to comment Share on other sites More sharing options...
nightspeed98 Posted August 6, 2010 Author Share Posted August 6, 2010 I have gone through 6 discs even including folders like my last head unit asked and numbered them as my avic used to read them.... maybe its the cd... Link to comment Share on other sites More sharing options...
John M Posted August 6, 2010 Share Posted August 6, 2010 Make a data CD, dump the files on there, and you're done. Nothing special is required. CD Burner XP is great (and free -- google cdbxp to find it). Does DVDs too, and works on any OS from XP onward. Link to comment Share on other sites More sharing options...
nightspeed98 Posted August 6, 2010 Author Share Posted August 6, 2010 always burn them as data. Audio is kinda restrictive in size Link to comment Share on other sites More sharing options...
Mr. Sinister Posted August 6, 2010 Share Posted August 6, 2010 Did you close the session on the CD? Link to comment Share on other sites More sharing options...
vr4Legacy Posted August 6, 2010 Share Posted August 6, 2010 I assume you are using a PC? If you are using a Mac you need to choose data under one of the options in iTunes, I forget which one. PC's should be as easy as drag and drop, and the Subaru HU does use folders. It will start at the root and then use the up/down category buttons to change. Also are your MP3's drm'd? The suby HU won't play them if they are......same goes for WMA files Link to comment Share on other sites More sharing options...
zmarko Posted August 7, 2010 Share Posted August 7, 2010 Is this on the stock head unit? If so, make a blank folder in the number 1 spot. Then put your mp3's in other folders after that. I had to do that I think when I had my '08 Spec B. Give it a try. Link to comment Share on other sites More sharing options...
nightspeed98 Posted August 8, 2010 Author Share Posted August 8, 2010 session was closed, yes on a PC, clean MP3's, stock HU, and will try Zmarko's suggestion tommorrow. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted August 9, 2010 Share Posted August 9, 2010 I don't need a blank folder or anything like that and it works fine for me. This might be a stupid question, but is your headunit mp3 capable? Link to comment Share on other sites More sharing options...
nightspeed98 Posted August 10, 2010 Author Share Posted August 10, 2010 yes it is Link to comment Share on other sites More sharing options...
nightspeed98 Posted November 7, 2010 Author Share Posted November 7, 2010 ok, i am willing to try again. Can anyone who has a working disc take a pic of the file arrangement and programs used and post it please? Link to comment Share on other sites More sharing options...
Strizzy Posted November 7, 2010 Share Posted November 7, 2010 Nero 8. Create MP3 Jukebox disc. Drag and drop. Burn. Enjoy. I don't do anything special to create the disc. What brand blanks are you using? My bad luck build Link to comment Share on other sites More sharing options...
nightspeed98 Posted November 8, 2010 Author Share Posted November 8, 2010 Memorex Link to comment Share on other sites More sharing options...
Crawdaddy79 Posted November 8, 2010 Share Posted November 8, 2010 Sometimes with Vista burning a data disc won't work for me. There is a setting that you can make a choice for, where it will allow it to work, but I can't be arsed to remember what that choice is. I use Windows XP for making discs - it's just another reason to hate Vista. Link to comment Share on other sites More sharing options...
nightspeed98 Posted November 8, 2010 Author Share Posted November 8, 2010 i have a gaming rig with 3 GPU's and can't burn a disc right thanks to vista huh? great Link to comment Share on other sites More sharing options...
whitetiger Posted November 8, 2010 Share Posted November 8, 2010 vista = burning fail. Use somthing like PowerISO. Link to comment Share on other sites More sharing options...
Strizzy Posted November 8, 2010 Share Posted November 8, 2010 I compare Vista with Windows ME... upgrade to XP Pro. My bad luck build Link to comment Share on other sites More sharing options...
MatsuDano Posted November 8, 2010 Share Posted November 8, 2010 There is nothing wrong with Vista burning. I've used Vista and windows 7 to create mp3 discs. Nightspeed, can you take a Screenshot of exactly what you are trying to do? Are you literally dragging and dropping and saying "burn"? Also, once the disc is "finished" can you read the disc as a regular data CD? Are the discs CD-R? CD+R and +RW might give you additional issues. Link to comment Share on other sites More sharing options...
nightspeed98 Posted November 9, 2010 Author Share Posted November 9, 2010 There is nothing wrong with Vista burning. I've used Vista and windows 7 to create mp3 discs. Nightspeed, can you take a Screenshot of exactly what you are trying to do? Are you literally dragging and dropping and saying "burn"? Also, once the disc is "finished" can you read the disc as a regular data CD? Are the discs CD-R? CD+R and +RW might give you additional issues. I will have to get back to you. Its 3:30am and I work nights, but I have tried multiple methods, drag and drop among them since it used to work with my avic N2/N3. The computer could read them. I'd double check them but they're somewhere on the road and the trash. "Unintended" acceleration out the window and the like. I believe the discs are CD-R Link to comment Share on other sites More sharing options...
nightspeed98 Posted November 10, 2010 Author Share Posted November 10, 2010 Toshiba Disc Creator worked!!! i appreciate all the assistance from you guys. Link to comment Share on other sites More sharing options...
MatsuDano Posted November 10, 2010 Share Posted November 10, 2010 congrats! enjoy the tunes! Link to comment Share on other sites More sharing options...
