aziankingz Posted September 13, 2014 Share Posted September 13, 2014 Hi All, Does anyone know the hose size diameter and length for the valve cover breather hose that goes to the pcv? It is on the passenger side closer to the front of the car/timing belt. Thanks! Link to comment Share on other sites More sharing options...
aziankingz Posted September 18, 2014 Author Share Posted September 18, 2014 anyone? Link to comment Share on other sites More sharing options...
vr4gt_2_Legacy Posted August 26, 2016 Share Posted August 26, 2016 so many threads of this and no friggen answer ;( Link to comment Share on other sites More sharing options...
ehsnils Posted August 26, 2016 Share Posted August 26, 2016 The easy way is to pop off the hose in one end and measure the diameter on the valve cover, then use a string to follow the hose and figure out the length. Or even easier - buy an OEM hose. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 26, 2016 Share Posted August 26, 2016 Go buy 3 or 4 ft of hose and you'll have plenty. The auto parts store guy can help you. Oh yea, OEM hoses...hey didn't I do that when I did the engine and few years back. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 26, 2016 Share Posted August 26, 2016 OEM fits as it should. They are more expensive but definitely worth it once you try to figure out how to route without putting a kink in standard hose. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 27, 2016 Share Posted August 27, 2016 good point about the kink. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
