Identify this TS uppipe...
PPAYER38
I'm about to buy a TS kit and I can't figure out what turbo this UP bolts to??
Guy says it is a Spec B UP but wanted some info from the LGT folks so please any info yiu have id like to hear good or bad... And please supply pictures if you have them
http://i450.photobucket.com/albums/qq224/ppayer38/ForumRunner_20120606_111735.jpg
http://i450.photobucket.com/albums/qq224/ppayer38/ForumRunner_20120606_111729.jpg
Looks kind of like my OEM TS UP for a TD04HLA-19T. Although, I don't recall the three extra studs on the "ears" from ~5-7oclock.
Just measured. The ports for the block/header flange of are 40mm, but immediately neck down to roughly 32mm as Unclemat suggested. It was too deep for the jaws of my caliper so I couldn't measure exactly, but 32 seems really close. The secondaries have 34mm ports.
The ports on the UP are all 35mm. This matches up nicely with the inlet ports on the turbo, shown on the previous page.
Pics:
http://img8.imageshack.us/img8/996/primaryports.jpg
http://img32.imageshack.us/img32/3809/secondaryports.jpg
http://img20.imageshack.us/img20/1552/upports.jpg
Awesome.. Thansk fro the pictures and help, I can see where the gasket/seal of the gasket was before those studs so I know I can chop them off just wanna be able to find a turbo to use this on(or atleast a turbine housing)
Looks like the Spec C item, at least from the photos I have of the stock parts.
Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs.
The up/header flange says it's a twinscroll Legacy part. Indeed it has extra studs on the turbo side.
It is not JDM Spec C part for sure.
it might be off the newer twinscroll turbo's the vf44's, its definitely not off a TD04HLA or vf36/37 turbos. what turbo does the kit come with that you are buying?
TD04HLA flange for comparison:
http://i32.photobucket.com/albums/d3/desperatedano/IMG_20120509_163832.jpg
The kit does not include a turbo. Just the pipes, it is a local friend and we ate trying to figure it out...
He wanted to use this on his new 207 swap but we noticed it was different when we got the motor and all his TS parts didn't match up.
  • 2 weeks later...
