Kevin03045 Posted June 24, 2008 Share Posted June 24, 2008 Ok First of all my car is stock, with the exception of a Zero Sports Intercooler splitter I picked up cheap. My Oil light came on today driving down the highway, I have not been hard on my car in anyway. The oil light seems to go out as soon as I start to slow down like it is a level issue but then comes back on as soon as I am stopped. I checked the level & its where it should be, also I still have 1500 miles before my next 3000 mile oil change which at this point I am going to do early. Any suggestion's before I head to the stealer ship? And oh yea I'm at about 37000 miles figures. Link to comment Share on other sites More sharing options...
meier motor sports Posted June 24, 2008 Share Posted June 24, 2008 tow it to the dealer! the light turning on means low oil pressure. low meaning barely enough. be sure there is enough oil in the car and if so get it towed Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 24, 2008 Author Share Posted June 24, 2008 It's there now. & I am keeping my fingers crossed. Link to comment Share on other sites More sharing options...
Infamous1 Posted June 24, 2008 Share Posted June 24, 2008 Should be covered under the 60K mile powertrain warranty. Link to comment Share on other sites More sharing options...
outahere Posted June 24, 2008 Share Posted June 24, 2008 I'm guessing your OP sensor is bad, or your pickup tube is cracked. Let us know what they find out. Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 24, 2008 Author Share Posted June 24, 2008 Well the dealership just called looks like I am in a loaner for the night. They replaced my intake throttle body about 3 weeks ago & they think its related. The rep said I am throwing two codes & one was a cam code but was unsure of the second one. I will keep you informed. PS. Oil was full so its not a low oil pressure issue. Link to comment Share on other sites More sharing options...
Infamous1 Posted June 24, 2008 Share Posted June 24, 2008 It can be a low pressure issue if the pickup is cracked..... Link to comment Share on other sites More sharing options...
Guest Posted June 24, 2008 Share Posted June 24, 2008 It can be a low pressure issue if the pickup is cracked..... +1 http://legacygt.com/forums/showthread.php?t=78603&highlight=important+tube Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 24, 2008 Author Share Posted June 24, 2008 +1 http://legacygt.com/forums/showthread.php?t=78603&highlight=important+tube I hope its not the oil pickup. As soon as i hear i will let you know, & its a good thing I am still fully stock beside the stereo & zero sports intake splitter. But the LegacyGT.com stickers on my two side windows wont help my efforts lol:lol:.. Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 25, 2008 Author Share Posted June 25, 2008 Well I got the official word today. MY FREAKING OIL PICK UP TUBE SHEARED CLEAN OFF. ATTN:: Legacy owners Keep a close eye on your pickup tubes!!!! The good news is it looks like there is no damage to the engine no metal in the oil pan They let me look at the oil which I was happy about. Its a good thing I caught it and had it towed to the dealer the tech said. Link to comment Share on other sites More sharing options...
Guest Posted June 25, 2008 Share Posted June 25, 2008 Ha, so your car is 06. You would be the second 06 LGT with the failure. I'd not take their word everything is fine. The engine has been starved for oil. I can imagine accelerated bearing wear and such. Looking at oil won't tell you much unless a serious failure already occured. You should have gotten sample of the oil and have it sent for oil analysis. You should do analsysis on the next oil after you get the car fixed as well. Is there a chance you could take a picture of the failed tube? Link to comment Share on other sites More sharing options...
Infamous1 Posted June 25, 2008 Share Posted June 25, 2008 Oh great now I can officially worry about this.... Great you caught it when you did. Link to comment Share on other sites More sharing options...
Guest Posted June 25, 2008 Share Posted June 25, 2008 Me, too. When I had shortblock replaced, the dealer also replaced the pickup tube (I asked them to inspect it just in case). I wonder if I got potentially worse one than the old one. Hard to say, since these failures on 04 STIs are also common. Surprisingly I haven't noticed one failure on 05 STI nor 05 LGT. Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 25, 2008 Author Share Posted June 25, 2008 Ha, so your car is 06. You would be the second 06 LGT with the failure. I'd not take their word everything is fine. The engine has been starved for oil. I can imagine accelerated bearing wear and such. Looking at oil won't tell you much unless a serious failure already occured. You should have gotten sample of the oil and have it sent for oil analysis. You should do analsysis on the next oil after you get the car fixed as well. Is there a chance you could take a picture of the failed tube? Great thanks for the info. I will try to get a picture of the tube, & will keep you all informed. Good call on the Oil analysis would have not even thought about it, where would I send something like this. Link to comment Share on other sites More sharing options...
Guest Posted June 25, 2008 Share Posted June 25, 2008 Great thanks for the info. I will try to get a picture of the tube, & will keep you all informed. Good call on the Oil analysis would have not even thought about it, where would I send something like this. E.g.: http://www.blackstone-labs.com/ - for typical run-of-the-mill UOA http://www.dysonanalysis.com/ - for more personalized/through UOA Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 25, 2008 Author Share Posted June 25, 2008 Great I will send it to http://www.dysonanalysis.com for testing & will post the results here once I get the feedback. Link to comment Share on other sites More sharing options...
outahere Posted June 25, 2008 Share Posted June 25, 2008 .................The good news is it looks like there is no damage to the engine no metal in the oil pan They let me look at the oil which I was happy about. Its a good thing I caught it and had it towed to the dealer the tech said. How long did you drive the car after the oil light came on? If you did not shut down immediately, there may be damage to bearings, pistons, cylinder bore, and camshafts that will show up later. Going with Dyson is an excellent choice. Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 25, 2008 Author Share Posted June 25, 2008 This started happening Monday night, & the oil light never came on solid. It flashed three to four times then went out for the rest of the night. I drove to work Tuesday morning which is a 20 min highway commute with no light, until I pulled into the company parking lot. I shut off the car asap & called The dealer. The check engine light never came on just the oil light. the engine light however did come on at the dealer when they pulled into the shop. Link to comment Share on other sites More sharing options...
vet Posted June 25, 2008 Share Posted June 25, 2008 Is there a difference between a flashing and a solid light (i.e. flashing = low, solid = none)? Or does a flashing light just mean that the oil pressure is fluctuating between low/none (light on) and normal (light off)? Link to comment Share on other sites More sharing options...
Guest Posted June 25, 2008 Share Posted June 25, 2008 This started happening Monday night, & the oil light never came on solid. It flashed three to four times then went out for the rest of the night. I drove to work Tuesday morning which is a 20 min highway commute with no light, until I pulled into the company parking lot. I shut off the car asap & called The dealer. The check engine light never came on just the oil light. the engine light however did come on at the dealer when they pulled into the shop. So they started it, despite oil pressure light, to pull into the shop? Link to comment Share on other sites More sharing options...
outahere Posted June 25, 2008 Share Posted June 25, 2008 This started happening Monday night, & the oil light never came on solid. It flashed three to four times then went out for the rest of the night. I drove to work Tuesday morning which is a 20 min highway commute with no light, until I pulled into the company parking lot........ When the oil pressure light comes on, it means the oil pressure is 2.1 psi (or lower), which is a very low oil pressure. At the very least, your engine has probably undergone some accelerated wear during the last few days. I'm surprised you didn't hear some rod knock. Link to comment Share on other sites More sharing options...
Beanboy Posted June 25, 2008 Share Posted June 25, 2008 I was so-so on getting gauges, but folks convinced me when going with a bigger turbo that it was a good idea. Looks like having an oil pressure gauge on a stock car might even be a good idea! Sorry to hear about the problem, at least you are under warranty and the engine didn't pop while on vacation somewhere. Keep us informed... -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 25, 2008 Author Share Posted June 25, 2008 So they started it, despite oil pressure light, to pull into the shop? Yes they did & I am unhappy about it:mad:. Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 25, 2008 Author Share Posted June 25, 2008 When the oil pressure light comes on, it means the oil pressure is 2.1 psi (or lower), which is a very low oil pressure. At the very least, your engine has probably undergone some accelerated wear during the last few days. I'm surprised you didn't hear some rod knock. No knock, no sounds, no loss of power. Only thing was the oil light which flashed a total counting Monday of 5 times. And by flashing i mean the light never fully came on full bright, if you were not looking you would definitely miss this. The light did not come on solid until yesterday morning in my company parking spot & that's when i shut it off asap & off to the dealership it went. Link to comment Share on other sites More sharing options...
Kevin03045 Posted June 25, 2008 Author Share Posted June 25, 2008 I was so-so on getting gauges, but folks convinced me when going with a bigger turbo that it was a good idea. Looks like having an oil pressure gauge on a stock car might even be a good idea! Sorry to hear about the problem, at least you are under warranty and the engine didn't pop while on vacation somewhere. Keep us informed... Thanks & yes I will keep you informed, pics will be posted tonight after i get home from work. And I will now be buying the STI gauge cluster or something similar. Link to comment Share on other sites More sharing options...
