SLegacy99 Posted August 27, 2006 Share Posted August 27, 2006 My Legacy HATES most hills. Sometimes, things are good and I roll back a little for fun and then shoot right outta there. However, there is on hill in particular on my way to work. I stop on it to turn right and yesterday my Legacy begrudgingly accelerated. Ive never seen such poor performance on a hill. Im not flooring it either, therefore Im not overwhelming the AWD or sucking all the air out from under my hood. My 4EAT did just fine on hills. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted August 27, 2006 Share Posted August 27, 2006 I had a '98 Outback with a fairly rare 5 speed. It has the same engine as yours. The only thing a 4EAT is going to do for you is downshift. At really slow speed, the 4EAT will be superior because the torque converter will let the engine rev to a higher speed. You can do this with a 5 speed but you'll burn your clutch. So, unless you're going really slow. I think the 5 speed should be able to do everything a 4EAT does. Ever drive on the freeway in 3rd gear? Link to comment Share on other sites More sharing options...
SLegacy99 Posted August 27, 2006 Author Share Posted August 27, 2006 Ok, but I am starting from a stop. So in the 4EAT it would start in first just as I would manually. Link to comment Share on other sites More sharing options...
rougeben83 Posted August 27, 2006 Share Posted August 27, 2006 I dunno, I just let the clutch slip a little less while I'm still on the brake, then release the clutch while the right foot gets on the gas. Timed right, the car won't even move back. Link to comment Share on other sites More sharing options...
Hiroki Posted August 27, 2006 Share Posted August 27, 2006 No problem for the 6spds. Link to comment Share on other sites More sharing options...
SLegacy99 Posted August 27, 2006 Author Share Posted August 27, 2006 I dunno, I just let the clutch slip a little less while I'm still on the brake, then release the clutch while the right foot gets on the gas. Timed right, the car won't even move back. Yes, perhaps I just need to take it up a few more RPMs. Link to comment Share on other sites More sharing options...
SLegacy99 Posted August 27, 2006 Author Share Posted August 27, 2006 No problem for the 6spds. Touche. I drove my dad's 330xi and no hesitation. However, it also has a firmer hill holder. The AWD on the BMW isnt as nice as Symmetrical though. I believe it is a 30/70 split and the rear tires tend to get lost traction more often then they should. Link to comment Share on other sites More sharing options...
vet Posted August 28, 2006 Share Posted August 28, 2006 You can definitely catch the LGT flat footed if you let the clutch out from a stop without giving it enough gas. When that happens the clutch is completely out and you are just off idle, like 1000-1200 rpms. At that point if you want to accelerate when you push the gas pedal it feels like it takes forever to build up some speed. No problem when you rev to 1500-200 rpms and slip the clutch. Link to comment Share on other sites More sharing options...
zadok Posted September 4, 2006 Share Posted September 4, 2006 Ok, was the clutch the entire way out, when you were pulling out? Reason i'm saying, the hill holder on my 99 L was insane once I installed the new clutch. I would coast up to a stop on a hill by my house and have the clutch in and applying the brake until stopped. Once stopped the hill holder works more, the harder you push on the brake. Sometimes it would be difficult to take off b\c the stupid hill holder was still engaged b\c I wasn't letting the clutch entirely out. After turning back the adjuster screw, everything is good now. Also, there are days where my little 2.2L just doesn't seem to want to go. Heat, moisture, and timing play a big part in how the car accelerates. Did your problem usually happen on hot & humid days? Just a couple of thoughts! '99 Legacy 2.2L 30th. (Stage 1 Exedy clutch, ACT flywheel, Custom Intake, JSPEC Hood, GT-B bumper, 17" SportMax Wheels, Premier DEH-P780MP, 40GB iPod) - Jason Link to comment Share on other sites More sharing options...
sframs Posted September 4, 2006 Share Posted September 4, 2006 i got caught at a stop sign. the hill was about 35-45 degrees. (the infamous san francisco hills). i burnt my clutch. there was smoke coming out of the hood. clutch took a while for the clutch to get back to normal. for a while it was hard to shift from 1st to 2nd. otherwise, my other hill experiences are relatively easy. rarely use the e brake. get a little roll back. i rev the engine a little more while letting the clutch out slowly. Link to comment Share on other sites More sharing options...
SLegacy99 Posted September 5, 2006 Author Share Posted September 5, 2006 No, its not a hill holder issue. I know that one for sure. Link to comment Share on other sites More sharing options...
waynekranzler Posted September 5, 2006 Share Posted September 5, 2006 My LGT -5 speed is no different on hills then any of the other MT cars I've owned. You just have to learn how to drive a MT. Link to comment Share on other sites More sharing options...
SLegacy99 Posted September 6, 2006 Author Share Posted September 6, 2006 My LGT -5 speed is no different on hills then any of the other MT cars I've owned. You just have to learn how to drive a MT. Well mine is different. Link to comment Share on other sites More sharing options...
SBT Posted September 6, 2006 Share Posted September 6, 2006 If it's a really steep hill, I just pull the e-Brake and let the car settle backwards against the rear brakes, keeping light pressure on the brake peddle for security purposes. Then when I'm ready to roll, I drop my foot off the brake pedal, unto the gas pedal, rev up high enough to get a good clutch engagement against the rear emergency brakes (which are still engaged), smoothely release the e-Brake and roll up/forward. Works very well everytime and takes the frustration out of rolling backwards or not having enough RPMs. Have taught countless men and women to drive MTs (from almost every brand under the sun) this way. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Flanders Posted September 7, 2006 Share Posted September 7, 2006 I run into this in San Francisco all the time. The car has no guts. Link to comment Share on other sites More sharing options...
SBT Posted September 7, 2006 Share Posted September 7, 2006 I've driven SF streets, hills and canyon pull-aways in MT-configured Subes (FI & NA) countless times with no issues. And, if I thought for a moment that I'd have a problem, I'd use the e-brake process I talked about above. It makes starting from a stop on a hill uber-easy. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
rougeben83 Posted September 7, 2006 Share Posted September 7, 2006 I learned to drive stick in my Legacy...the clutch takeup is a little tricky but once you learn around it, I've had no difficulty starting up even steep inclines (like parking structures, etc.). Just need to get the right amount of gas and clutch release timed right and there won't be any drama. Link to comment Share on other sites More sharing options...
