2005 motor swap
Jokes aside, it just isn't a feasible swap. It's a discussion that's been repeated countless times on the forum. Even if hypothetically you could source an inexpensive EJ257 and do all the labor yourself the car will still be lacking in several other areas (ie transmission, brakes, etc.). And anyway, you could find an 05 GT in decent shape for under $10k. Do dat instead.
  • 2 years later...
[ame=http://www.youtube.com/watch?v=7sipulrDCzk]Subaru Legacy 2.5i NA Engine Failure sound - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=MVyWq3MupSI]Failure of a 2006 Subaru Legacy 2.5i - Do not Buy one without compression testing first - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=g6Fi_xA41z4]2006 Subaru Legacy 2.5i Only Starts when cold and SQUEAKS A LOT MORE USUALLY - YouTube[/ame]
does this sound like i need a new engine or a rebuild is possible?
metal filings on oil dipstick visible.
only starts and does run from a cold start.
once it has been shut off and its warm, it makes all those noises you hear above.
also knocks heavily once its running from cold start.
oil levels all good! so confused. Third party warranty I have.
car is 2006 legacy 2.5 NA - 146000kms
the car i have had for a little over a month now. im sure the dealership that sold it to me knew it was a pile of junk. it always would hesitate under load when pushed. I had the spark plugs changed when I saw that there was oil in them. then i had the VCG changed on both sides of the engine. wondering if either of these could be the cause of what happen?
It basically happened when i was on the highway, gave the car a good push from 40km to 140km while near redline but never at redline. soon as i let off the gas pedal. check engine light came on. pulled over and while the car is still running ALL the lights the car can show on the cluster, came on at once. then i turned it off and the noises you hear above is all i got from the car. had it towed home.
3rd party warranty only covers 750/repair. so im stuck badly. i know a rebuilt / engine swap costs thousands. its gonna suck to spend on a car i just bought for 8000$
god damn dealership want to go cause some havoc over there <_<
pics from the day i was getting spark plugs changed. this was BEFORE getting VCG changed. car was running fine for weeks.
http://www.i-club.com/forums/attachments/conversions-transplants-swaps-107/79921d1357154009-2006-legacy-2-5i-turns-but-turns-off-immediately-knocking-squeaks-engine-photo-2-jpg
http://www.i-club.com/forums/attachments/conversions-transplants-swaps-107/79922d1357154015-2006-legacy-2-5i-turns-but-turns-off-immediately-knocking-squeaks-engine-photo-1-jpg
Did you keep a eye on the oil level ?
These cars use oil.
You can get a OEM short block for 25% off from
http://legacygt.com/index.php?page=vendors&
I just put a new short block in my 05 GT wagon.
Engine Build - Click Here
so they changed them.. here is a picture when the job was being done :spin:
i stood there for over an hour in the cold shop making sure they didn't miss anything and still. here i am with a dead car
not sure if serious? your engine is toast dude, rod knock or main bearing has spun which means internal lubrication failure or over-reving (or going on the highway in 3rd and dropping to first, rev limiters don't always cut ignition in time). you need a new engine, forget the VCG's. you can't practically put an LGT (EJ255 DOHC) motor into your car, sorry. unless you want to swap everything that's attached to it too... it would be cheaper just to buy an LGT.
These cars use oil.
the oil level i watched it all the time. never fell once throughout the jobs being done. spark plug job and even after the VCG job no oil level reduction at all!
sounds like this is what happen to me on the highway...
wish it hadn't. and im not going for a LGT engine. the 3rd part warranty people have a certified shop that rebuilds 75% of their engines.. so that's where the car is now.. could take months im guessing :confused:
