dr_sharp Posted July 7, 2012 Share Posted July 7, 2012 Anyone else? Wondering if I should remove it or just have it welded back. lol Link to comment Share on other sites More sharing options...
Max Capacity Posted July 7, 2012 Share Posted July 7, 2012 Does it rattle ? If not I'd leave it there. If you remove it, I'd wrap the pipe with DEI heat wrap. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dr_sharp Posted July 7, 2012 Author Share Posted July 7, 2012 I'm not 100% sure, but it could explain the strange rattling I've been hearing in the 2-3krpm partial throttle situations lol lol Link to comment Share on other sites More sharing options...
Max Capacity Posted July 7, 2012 Share Posted July 7, 2012 Either that one or the next heat shield down, by #1 &3 cylinders. Hind sight 20/20 mine is loose, I should have done the DEI heat warp when the engine was out. I have the wrap just waiting for cooler weather, like late Sept to do it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dr_sharp Posted July 7, 2012 Author Share Posted July 7, 2012 So does anyone sell aftermarket UP that doesn't crack? lol Link to comment Share on other sites More sharing options...
SSpeed Posted July 7, 2012 Share Posted July 7, 2012 Yep, mine cracked there. I had welded it and wrapped it before switching to the Grimmspeed. Link to comment Share on other sites More sharing options...
dr_sharp Posted July 7, 2012 Author Share Posted July 7, 2012 How long have you been rocking the GS? lol Link to comment Share on other sites More sharing options...
SSpeed Posted July 7, 2012 Share Posted July 7, 2012 Let's see, about 6 months at the most. I did it mostly as an experiment with a little port matching. With testing I think the sti one is just as good or maybe even better since it has the heat shield. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 8, 2012 Share Posted July 8, 2012 I have a Invidia catless up on my 05. Been there for 2 years. http://www.tuningalliance.com/searchResults.php?query=&cat_id=21&mfr_id=23 Contact Mike and tell him I sent you. Byron 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
