bamorgan7 Posted May 24, 2011 Share Posted May 24, 2011 Im was looking at legacys awhile back but since my recent car is no more, I was wondering how long do the turbos usually last? I have my eye on 2 lgt both auto both in at the 100k mark. Here are the links to them. Thank you http://www.autotrader.com/fyc/vdp.jsp?ct=u&car_id=296423865&dealer_id=1339223&car_year=2005&doors=&systime=&position=top&model=LEGACY&search_lang=en&start_year=2005&keywordsfyc=&keywordsrep=&highlightFirstMakeModel=&search_type=both&distance=200&min_price=&rdm=1306280849371&drive=&marketZipError=false&advanced=&fuel=&keywords_display=&lastBeginningStartYear=1981&end_year=2007&showZipError=y&make2=&certified=&engine=&dma=GREENVILLE-SPART-ASHEVILLE_ASH&page_location=findacar%3A%3Aispsearchform&body_code=0&transmission=&default_sort=priceDESC&max_mileage=&address=28806&color=&sort_type=priceASC&max_price=&make=SUB&num_records=100&seller_type=b&cardist=84&standard=false&rdpage=thumb http://www.autotrader.com/fyc/vdp.jsp?ct=u&car_id=299421898&dealer_id=97926&car_year=2005&doors=&systime=&position=top&model=LEGACY&search_lang=en&start_year=2005&keywordsfyc=&keywordsrep=&highlightFirstMakeModel=&search_type=both&distance=200&min_price=&rdm=1306280849371&drive=&marketZipError=false&advanced=&fuel=&keywords_display=&lastBeginningStartYear=1981&end_year=2007&showZipError=y&make2=&certified=&engine=&dma=GREENVILLE-SPART-ASHEVILLE_ASH&page_location=findacar%3A%3Aispsearchform&body_code=0&transmission=&default_sort=priceDESC&max_mileage=&address=28806&color=&sort_type=priceASC&max_price=&make=SUB&num_records=100&seller_type=b&cardist=211&standard=false&rdpage=thumb Link to comment Share on other sites More sharing options...
RabidWombat Posted May 26, 2011 Share Posted May 26, 2011 Around 100k-120k, with wide variability. Some die at less than 60k, some people are still on their stock turbo at 150k+. That's probably not the answer you wanted to hear. If you're planning on modding the car anyway, a preventive turbo replacement is not a bad idea. Do a search for "banjo bolt" and you'll see a lot of turbo failure issues. The main thing with turbo cars is to be aware of the signs of turbo failure. It usually starts with an excessive whine as the turbo spins down or an increase in oil consumption. If you experience loss of power issues, the turbo is completely blown and should not be driven further (get it towed). Link to comment Share on other sites More sharing options...
Wrench Posted May 30, 2011 Share Posted May 30, 2011 Auto< Manual Link to comment Share on other sites More sharing options...
Drift Motion Posted May 30, 2011 Share Posted May 30, 2011 maintenance record is the key! and at 100k, there is a costly maintenance at 105k for timing belt Link to comment Share on other sites More sharing options...
