GreenMarine Posted April 25, 2011 Share Posted April 25, 2011 So my rear view mirror is so floppy it would probably move if I exhaled strongly at it... Does anyone know if the tension is adjustable (and if so - HOW TO DO IT?)??... It is so bad that I have to adjust my rear view mirror EVERY FEW MILES because it just droops down with vibrations while driving!!! Thanks in advance! Link to comment Share on other sites More sharing options...
Baddog Posted April 25, 2011 Share Posted April 25, 2011 I believe it is a "Torx" screw driver. It is on the left side of the mirror. You should see it. Try tightening up that a bit. Link to comment Share on other sites More sharing options...
WESTcoast Posted April 25, 2011 Share Posted April 25, 2011 yup happen to mine its torx screw bit that you will need and your all set! Link to comment Share on other sites More sharing options...
Feldman Posted April 25, 2011 Share Posted April 25, 2011 I have this problem too! I was going to pull one from a junkyard so thank you Baddog you just saved me $6 Link to comment Share on other sites More sharing options...
johnegg Posted April 26, 2011 Share Posted April 26, 2011 there is a torx screw and if tightening it helps, great. there is a chance that the piece of spring steel inside the ball joint is broken. if that is the case you might try opening it up and installing a small piece of thin card board or folded paper. anything to creat enough friction to ''pinch'' the ball. i've doe it twice. Link to comment Share on other sites More sharing options...
PhilT Posted April 26, 2011 Share Posted April 26, 2011 Hold it in the position you want it, then put of crazy glue on the joint, it will never move again. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
donalduck_69 Posted April 26, 2011 Share Posted April 26, 2011 I just tightened mine with a T20 torx screwdriver. Mine wasn't as bad as yours sounds but it did move pretty freely. Simple fix. Good luck. Nafe Link to comment Share on other sites More sharing options...
Feldman Posted April 26, 2011 Share Posted April 26, 2011 I just did mine too, i can confirm T20 as the size as well. My screw seemed pretty tight but i got about a quarter turn on it at best and its nice and firm now Link to comment Share on other sites More sharing options...
mwiener2 Posted April 26, 2011 Share Posted April 26, 2011 I gave mine Viagra My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted April 26, 2011 I Donated Share Posted April 26, 2011 I just did mine too, i can confirm T20 as the size as well. My screw seemed pretty tight but i got about a quarter turn on it at best and its nice and firm now I gave mine Viagra hahahahahahha classic -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
GreenMarine Posted April 26, 2011 Author Share Posted April 26, 2011 I believe it is a "Torx" screw driver. It is on the left side of the mirror. You should see it. Try tightening up that a bit. Thanks for that!! I'll swing by Autozone tomorrow and try to sort this mess out yup happen to mine its torx screw bit that you will need and your all set! Thanks for the confirmation!! Hold it in the position you want it, then put of crazy glue on the joint, it will never move again. This may be my very last option I gave mine Viagra Hmmm, if my torx attempt doesn't work I may have to slip one of these little pills into my car... The question is, WHERE?? Do I grind it up and stick it in the fuel filler? Thanks for all the answers guys!! This community is a great resource and although it is alot smaller than NASIOC, youguys have been alot more helpful and receptive to questions in my short time of owning a Legacy ... Stay that way because the girlfriend's next car may be a new Legacy Outback Link to comment Share on other sites More sharing options...
stevenva Posted April 26, 2011 Share Posted April 26, 2011 I had the same problem. After tightening the torx screw the mirror still moved on strong bass notes. It's a ball & socket type joint. Dissamble, add a couple drops of blue loctite thread sealer, reassamble. Problem solved after over a years use. (and the mirror is still adjustable) RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
GreenMarine Posted April 26, 2011 Author Share Posted April 26, 2011 It WORKED!! The tool is a "T-20" Torx Simply tightened the screw on the left side of the mirror support arm and all was well Thanks to all!! Link to comment Share on other sites More sharing options...
Lookatmyrust Posted April 27, 2011 Share Posted April 27, 2011 i love of some people are just figuring this out! no offense but did anybody look at the mirror first to see if they could fix it? haha we all depend so much on the internet. cracks me up. Link to comment Share on other sites More sharing options...
nmd003 Posted April 29, 2011 Share Posted April 29, 2011 If it's any consolation, I figured it out without looking on the interwebs. I'll have to do the loctite deal on mine though cuz it keeps loosening up. Link to comment Share on other sites More sharing options...
Lookatmyrust Posted April 29, 2011 Share Posted April 29, 2011 its worse when you got your systems turned up. Link to comment Share on other sites More sharing options...
