The Murdocta Posted December 13, 2010 Share Posted December 13, 2010 My friend is having issues with his 05 LGT. He is starting to notice a strange rattle sound coming from somewhere around the engine when revving towards 2000 RPMs. This does not sound good at all... This sound is also noticeable while driving. Below is a link to a YouTube video of the sound I took from my phone. Has anyone heard this sound before have any ideas as to what it could be? Any help is appreciated. [ame= ] [/ame] Thanks Will it Blend? That is the question! Link to comment Share on other sites More sharing options...
bmx045 Posted December 13, 2010 Share Posted December 13, 2010 Is your ventilation on windshield defrost? Kinda sounds like the A/C clutch isn't engaging. It cycles on/off every minute or so when your ventilation setting is on that. Link to comment Share on other sites More sharing options...
The Murdocta Posted December 14, 2010 Author Share Posted December 14, 2010 I'm not sure if this is the issue. Defrost was not enabled when testing this. It has to do with engine components. Somone suggested it might be a push rod for a piston. However, wouldn't that sound never go away in that case. This seems to be off and on at different RPMs. Possibly something to do with power steering pump or A/C pump? Will it Blend? That is the question! Link to comment Share on other sites More sharing options...
bmx045 Posted December 14, 2010 Share Posted December 14, 2010 How's your oil level? Link to comment Share on other sites More sharing options...
The Murdocta Posted December 14, 2010 Author Share Posted December 14, 2010 Again this is my friends Legacy, he is apparently 1000 miles overdue for an oil change. AKA 4000 miles since last change, hes going to check the oil level at lunch today. Will it Blend? That is the question! Link to comment Share on other sites More sharing options...
Dutch Eagle Posted December 14, 2010 Share Posted December 14, 2010 Bad news. Sounds 100% like one of the big-end bearings is dying. Very common problem on these engines. This one is a bit further gone: [ame=http://www.youtube.com/watch?v=DIS5zjylb4c]YouTube - Poorly Scooby[/ame] Engine must have new bearings and new piston-rod's. Pistons themselves are still o.k. I think. Tell your friend to be wise and let the std. stuff be replaced by forged rods en ACL(trimetal) bearings when he get's the engine repaired. Cause thót is where the weak spot is, the cause of a lot of EJ20's to break down like this. (disforming endcaps of the piston-caps due to high rev's) And don't start the engine anymore, cause in no time you'll get metal parts everywhere which can only make the cost's of repair a lot higher. If you want more info just ask. A friend of mine is engine and gearbox (re-) builder, specialized in Subaru, so I know most in's and out's. Link to comment Share on other sites More sharing options...
The Murdocta Posted December 14, 2010 Author Share Posted December 14, 2010 *Update* Apparently he checked the oil and it was Low. exactly at the L on the dipstick. He put one Quart in and the noise seemed to go away. Do you think it was because of the oil or it the added oil just masking the sound somehow? Essentially he heard the sound really bad this morning on startup and driving and now the sound is 100% gone. Any thoughts? The above sounds like a serious engine re-build and hopefully it does not come down to that... Will it Blend? That is the question! Link to comment Share on other sites More sharing options...
bmx045 Posted December 14, 2010 Share Posted December 14, 2010 It's tough to say, these engines can consume oil so check the level once a week. It only takes a quart between L and F on the dipstick. It's vital these engines have enough oil in them. Link to comment Share on other sites More sharing options...
mwiener2 Posted December 14, 2010 Share Posted December 14, 2010 Sounds like bad bearings. He should start saving for a rebuild... as early as tomorrow My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
John M Posted December 15, 2010 Share Posted December 15, 2010 Yep, that noise will be back with a vengeance. It could be the Tbelt tensioner but I wasn't so lucky. Since nobody buys LGTs with bad engines mine will be on engine #3 sometime next year. Link to comment Share on other sites More sharing options...
Dutch Eagle Posted December 15, 2010 Share Posted December 15, 2010 Adding extra new oil will make the remaining (old) oil more viscous. This can be enough to get rid of the rattle for a short time. Actually this is why some 'nice' people quickly sell an engine when these problems start to occur. They throw in a very viscous oil like a 20w60 or higher, and sell the engine as good as new.... Your friend is facing a rebuilt or e new engine. Link to comment Share on other sites More sharing options...
porterdog Posted December 16, 2010 Share Posted December 16, 2010 ...mine will be on engine #3 sometime next year. WTF, over?! What was the deal with #'s 1 and 2? Link to comment Share on other sites More sharing options...
John M Posted December 16, 2010 Share Posted December 16, 2010 #1 bit the dust thanks to the factory ring lands. The second one was fully built and at 5k miles decided to self-destruct when the vac line to the fuel pressure regulator came off. Stupid Subaru doesn't put a clamp or even barbs on hoses that see pressure. My engine builder didn't re-zip-tie it after the rebuild like I had done soon after buying the car. A 2 mile in-town trip with that hose off = trashed bearings. $200 is hard for me to come up with right now so $2000+ might as well be a million. Link to comment Share on other sites More sharing options...
Telephonewire Posted February 13, 2012 Share Posted February 13, 2012 *Update* Apparently he checked the oil and it was Low. exactly at the L on the dipstick. He put one Quart in and the noise seemed to go away. Do you think it was because of the oil or it the added oil just masking the sound somehow? Essentially he heard the sound really bad this morning on startup and driving and now the sound is 100% gone. Any thoughts? The above sounds like a serious engine re-build and hopefully it does not come down to that... Hi - I know your post was a long time ago but did the noise ever come back or has it remained ok ever since? Regards, Telephonewire Link to comment Share on other sites More sharing options...
PearlBlueGT Posted February 13, 2012 Share Posted February 13, 2012 rod bearing knock Link to comment Share on other sites More sharing options...
BlackGT2005 Posted February 13, 2012 Share Posted February 13, 2012 thats rod bearing knock all day same thing happened to my 04 WRX i just SOLD it for 5k and called it a day. Link to comment Share on other sites More sharing options...
